something that is still being worked on now and again.
XBE long chassis
VIDEO:
This is another one of a kind build that I did. And yes, it's 2 fast 4 U!!!twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
This is a stretched XB-E that is currently getting new diff housings in front and rear they and the wheel hubs are made by 7075rc. 24mm hex adapters are Ramtech and the motor is the beast 524 2Y 910 kv motor with 200 amp esc that has caps added running on 8s Nano-tech 65-130c 5000 lipos. carbon fiber body is vac bagged with impact resin making it 18 time stronger than the losi body. And is lighter to boot!
Last edited by twissted; 01-02-2014, 11:58 AM.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
Maiden run with camera on board!!
I changed the front springs to the Losi 5 blue (have them on back already) and loosened the motor pinion gear so it not noisy any longer.Last edited by twissted; 01-15-2014, 01:48 AM.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
