Hello all yee HVAC guru's! I know there are a couple or at least one skulking about in here.
I have this thermostat in my apartment. It controls my own independent HVAC unit that is electric forced air plus an A/C for summer.
I would like to know about the center dial and how to set it so the temp keeps more stable on cold days.
It has some wording on it but, it doesn't seem like any cycle changes when I swing that little metal dial to whatever place.
It is very old and if I wanted to replace it how would I know which wire goes where on the new one (assuming it will be different??)
I know the basics, as the mercury switch falls to the right the heater turns off as it goes the other direction it triggers (closes cct) and heat turns on.
On damp days like today it seems like I cannot get warm no matter what, well unless I crank the hell out of the heat.
Since the thermal coil is so old and caked with Nicotine and tar from previous tenant, could it be out of calibration causing improper temp reading? I dunno, it drives me nuts. I'm either too cold or too hot...
Maybe it's Manopause?? LOL...
Any help is greatly appreciated!!
Chillin'
Chillin'
Nortavlag Bulc
? ONLY IF THEY WORK
Now I need to borrow a clamp meter. I could do it with shunt but, haven't done that since High school.
