Has anyone gotten their hands on one yet??? I would love to know what is different about the hull design compared to previous model. Apparently the hull doesn't porpoise as much as before, from what I observed in the HorizonHobby YouTube video below.
In ProBoat's website picture gallery there is a sneak peek of the internal layout of the new hull design, looks like they have put in some proper battery holders on top of trays and improved the space by lowering the trays closer to the bottom of the hull so as to fit larger/taller battery packs. The battery holders can slide fore and aft on the trays to adjust the COG. However the amount of COG adjustment for the battery packs does look limited compared to before.
The new 120A ESC looks beefier with better water cooling than the previous 80A version. Though the new 120A ESC does look a little plain with no blue anodized heatsink.
The motor mount looks much sturdier.
The radio antenna has changed location and is shorter and stubbier.
I am excited to find out more about the ride pads on the new hull. Many racers believe that the ride pads on the previous hull must be blueprinted and sharpened to eliminate porpoising. I wonder if PB has done some kind of improvement to the ride pads for them to handle the extra speed of the 2000kv motor on 6s? The previous hull was already maxed out with the 1800kv/6S setup. Looking at the picture supplied on ProBoat's website, the bottom of the hull design looks slightly different. The ride pads appear flatter than before and the flexshaft tube appears to be housed inside and aerodynamic mini keel for improved airflow, perhaps that helps reduce porpoising?
Transmitter is the same Spektrum DX2E, however the receiver has been upgraded(?) from a MR200 to a SR410.
I wonder if the flexshaft has been beefed up as well? Many BJ29 owners did blowup the stock flexshaft with the 1800kv/6S setup.
According to the ProBoat website's product description, the propeller size is now 63mm(WT...??!!)x1.6p. That's gotta be a typo!!! The factory metal prop used to be a 40mmx1.6p=63mm of pitch.
***Moderators: If I am not supposed to hotlink external retail websites, I apologize, please remove it accordingly.***
