The bolt pattern is the same as my Neu 1515 1y motor so swapping motors will be easy (dual bolt pattern m3 or m4). Both the 5mm and 8mm shaft versions are avaliable. Can size is the same as 1521 size motors. Notice the old style motor wires on the newer 1518.
The 1515 has a can diameter of 1.536". The 1518 has a can diameter of 1.574"
