Hey all, I have been tuning my rigger now for a few weeks, as some of you may have read my post on the 6s rigger only going 37 mph...more and more testing KNOWING this hull should be able to run in the 60s...I have narrowed it down to the magnets in my feigao being the problem. Rather than tearing apart my 1/8th scale buggy for a brushless motor, I decided to go way out on a limb here and order a very high powered outrunner for testing. It is the Scorpion hk 3026-1600kv motor to be used on 6s. Max Watts about 1470watts at 70 amps. Magnets capable of 392 degrees F. and only $74.
I have been on many heli and airplane threads, and all of the users call these little motors, torque monsters. The 1/7th and 8th scale unlimiteds have been running the hk 4035 series on 8s with great success and no water cooling (since it is an outrunner). I thought I would give it a shot. since spec wise, it is higher amps and watts than the feigao xl series....take a look at the pics...at the size difference. If these motors, can push a 43inch hull...the smaller version Has to be able to push a light rigger. Testing tonight...can't wait. The kv and amps/wattage of the motor I am testing is similar to that of a 10xl. Only difference is the size...but there really is no comparison between an inrunner and outrunner based on dimensions alone. I ran it in my shop for a few seconds last night and this thing whines!!! it has a very unique spool-down action and sounds MEAN...again not what I expected out of an outrunner....it almost coasts...not an abrupt stopping action like an inrunner.
Will give results in the morning.
