Ben, the only way I can reply is via a PM, as I do not wished to be flamed and I have not received one from you as of this date and time, but if you are serious on this hull give me a shout.
Since I spent maybe 10 years or more out of the hobby, I missed a lot of stuff. I came across this boat and wanted to know more about it. To be honest, I am specifically interested to find out if the inside edges of the tunnel are parallel or toed in at the bow. And if so, by how much (in degrees or portion thereof).
I'm on a personal mission to go through the different design changes over the years and coming to my own conclusions as to which improvements have different results. Only by reviewing design improvements can I take advantage of these designs while operating or setting up boats in the future.
I just hate to be oblivious regarding the what or why one thing works better than another. Meanwhile, I can appreciate that some things work better with others and why they don't work as well with something else. I hope that makes sense.
Right now, posting pictures would be most helpful.
Yes, Steven here is an answer to a pm. The persons name has been deleted ,fine, apart from me loosing my temper and almost being banned!
The original power was an aquacraft Ep-1, as I wanted a semi scale look and it was modified to run anS27 power plant and it sucked. I have recently ordered a bottom leg conversion kit and plan an XL motor, size still to be decided.
The Ep-1 was also modified to run a Y535
