52 inch Super Hawaii
  • H2OCamel
    FAST ELECTRIC EVERYTHING
    • Oct 2007
    • 484
    Hi Folks,
    I have a 52" Super Hawaii comming to me. I am planing on a 2 motor 2 drive minimum setup and if i can make it fit a four drive scale setup would be killer! :) I am looking for suggestions for motor and prop options. this will be a sport boat. It is scale and I'm looking for scale speeds. I will also do a build thread when I get it.
    Brushed or brushless works for me.
    Thanks in advance,
    Chris
    "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
  • phase
    • May 2008
    • 218
    just a suggestion.. i dont know if it will work but you should try duall sv systems wit 4 batteries.. and also i suggest that you redo all the hardware and gearbox..
    • lonewolf
      • Jul 2007
      • 658
      A 52 in hull requires some serious power, 4 sv set ups might work??? but 2 would struggle and most likely let out the genie. twin 800 brushed would work well, id guess running 447 or better. There are several feigao combinations that would work also. but to get any real speed kb xl would be a good option...
      Twin cat 9xl,... 29 titan 8xl,....37 in mono kb48 8xl.... 42 in twin elc cat project... 42 in gasser cat 260 modded zenoh''' planes and trucks....
      • Doby
        KANADA RULES!
        • 7280
        He did say 52",,,so if thats true, dual SV systems will plane it , but not much more.
        Grand River Marine Modellers
        • H2OCamel
          • Oct 2007
          • 484
          Yes it is 52" or 133cm!
          I have the ABC SuperHawaii (abs plastic) that has a firebreathing 700 that is stupid fast and is crazy to drive! Phase I did take out the gearbox and run it direct. It will powwer slide like a jet boat :D
          This SH is Fiberglass and is a sacle replica of the true boat. (no Rocker bottom) I can get 800's easy enough, if i can fit it I'll go four. The KB's sound promising too They are also smaller dia. than the 800's so I am leaning this direction.
          It will take three weeks before I get the hull so I don't know all the internal dimentions yet. It is a gas hull that I will convert to electric. I will post picts when it comes in.
          IS IT HERE YET!!?
          • Doby
            KANADA RULES!
            • 7280
            Any links to the boat??
            • H2OCamel
              • Oct 2007
              • 484
              Here you go Doby:
              Paul also makes a 215cm or 84.5" version they are not cheap though!
              • H2OCamel
                • Oct 2007
                • 484
                Update:
                I Sent the paypal for Paul to make my hull on 7/9/2008 I was told it would take 14 days to finish it. Well It has been 3 months and no boat yet! I have sent e-mails and the last responce was 8/30/2008 when Paul said he just got back from holiday and that he would check on the molder to see what the hold up was and get back to me on the following monday. well I have not heard from him since. I have sent e-mails with no response. I have filed a complaint with PAYPAL who says they can do nothing to help. I AM VERY UPSET! I am out one Super Hawwaii hull as well as $660!
                • Doby
                  KANADA RULES!
                  • 7280
                  Looks like "Precison in Perfection" Doesn't mean "Percision in Delivery",,,or "Precision in Customer Service".
                  Lets hope it eventually shows up. I'm looking forward to this build!
                  • H2OCamel
                    • Oct 2007
                    • 484
                    Doby,
                    LOL
                    I hope it ins't something like he is in the hospital or worse Dead. I have been looking forward to this boat and still want it if I can get it. Time will tell I guess.
                    • Ocean Racer
                      • Sep 2007
                      • 502
                      I want to say that another member did a super hawaii the same size a while ago. Im not sure what he named it but i remember they did the same boat i think with dual 800's.
                      Failure is the First step to SUCCESS
                      • axel
                        • May 2007
                        • 127
                        Originally posted by H2OCamel
                        Update:
                        Any change in the meantime????
                        Axel
                        • H2OCamel
                          • Oct 2007
                          • 484
                          None whatsoever..............
                          • Doby
                            KANADA RULES!
                            • 7280
                            Any word from those Bozo's yet on when it will arrive??? Any corespondance at all??
                            • H2OCamel
                              • Oct 2007
                              • 484
                              doby,
                              not a peep i even back charged through paypal with no response that way either. maybe i need to go on a hunting trip to the UK ;-)
