44" Avenger Pro 10S Cat!
  • txboatpilot
    • Oct 2007
    • 1494
    Starting a New Project:
    I am going to start building my 44" Avenger Pro 10S Cat... I got in the motor and speed control today!!! I will post more pictures tomarrow...
    I am first going to try the NEU 2215/2Y (750kv) with Castle HV-180 esc and 10S lipo.... If I run into any issues, there is always the 2230 and HV-240....LOL
    Setup::
    1. Aeromarine 44" Avenger Pro (light electric lay-up)
    2. Neu 2215/2Y (750kv)
    3. Castle HV-180 esc
    4. Top Secret Boats Hardware (strut w/skeg, rudder assembly, blue anodized water outlets/ thu-hull fittings and 1/4 scale servo mount)
    5. Dasboata,,,1/4 flex shaft w/ step-down for 3/16 prop
    6. OSE,,, 8mm-- .250 Coupler & 8mm thrust bearing
    7. Hitec 755-MG servo
    8. All 5.5mm connectors on Battery leads and esc power input wires,,, 6mm connectors on motor to esc
    9. 4X 5S 5000mAh PolyRC lipos
    10. X450, X452, X455, and X457 for testing... (All are OSE S&B props!)
    Here are a couple pictures of the motor, esc and hull....
    Nothing like keeping you lipos warm and your prop wet!!
  • Bill-SOCAL
    • Nov 2007
    • 1404
    I'm converting mine to the 2215 as well. What are you going to do for a motor mount??
    Don't get me started
    • Doby
      KANADA RULES!
      • 7280
      Nice Rich!
      Where did you get the Hydra? Mines apparently 2 weeks away still.
      Grand River Marine Modellers
      • Steven Vaccaro
        • 8718
        Originally posted by Doby
        Nice Rich!
        I have a bunch I got. They are not on the site, because they are all accounted for. You asked me to hold one for you and I did. the motor isnt in yet. If you dont want it let me know asap!
        Steven Vaccaro
        • calcagno45
          • Mar 2008
          • 1006
          If my eyes are right, thats 4 rows of cooling plates on the HV180? Shouldn't have any heat issues....
          If so, would it be feasable to run 2 water pickups and run 2 sets of cooling lines to the HV180? I guess I'm looking at circulating the water 2 times around in each line instead of 4 times around in 1 line. More heat dispersement?
          I hope that made sense.
          • txboatpilot
            • Oct 2007
            • 1494
            calcagno45...
            Yes, there are 4 plates total... I dont expect to pull more than 90-120 cont. amps, so heat should not be an issue...
            Yes, there will be 2/ water pick-ups... I will try a few different circulation methods... Steven here at OSE is getting me a "tester" waterjacket for the 2215!! So there will be many options for the cooling lines....
            I am installing the hardware today, I will have more pictures later....
            • txboatpilot
              • Oct 2007
              • 1494
              I am going to build it all out of ply... Unless someone comes up with a nice alum. mount soon....
              • txboatpilot
                • Oct 2007
                • 1494
                More pictures.... Hardware is installed...
                I cant wait to try the 2215/2Y (750kv), so I put in in the 40" Insane Cat for some testing!!
                The Insane Cat had a 2280/10 (740kv), so it should be a good comparison test...
                I will also test the HV-180 in the Insane Cat w/ the 2215.... Just to get some info, while I build the Avenger Pro...
                The last picture is the Lehner 2280 beside the NEU 2215....
                • calcagno45
                  • Mar 2008
                  • 1006
                  Good luck with the testing. Can't wait to see some video's too!!
                  I was trying my brain out, lol. I dont use it much but that seemed like a good try. I see that the rudder has 2 water pickups on it.
                  What size cable will you be running?
                  • SJFE
                    • 4735
                    Is that aquatech HW?????
                    • txboatpilot
                      • Oct 2007
                      • 1494
                      No sir,,, it is from Top Secret Boats... He makes really nice gasser hardware! I have used his stuff in the past with great sucess, also there are a couple gassers in our club that run TSB hardware.... Very nice CNC machined, T6 Alm. all s/s screws included.... I run his Nitro hardware on my Mean Machine, it is much like the speedmaster stuff.....
                      • SJFE
                        • 4735
                        I have his site book marked. I may buy one of his rudders for the SW36.
                        • blakybob
                          • 126
                          How does the stepped-down flex cable hold up?
                          Blake
                          • crazzy maxx
                            • Dec 2007
                            • 498
                            Top Secret Has Ssome Nice Hulls/ Hardwear. I Run His Hardwear On My Gas And I Love It.
                            Got Any Updates Or Videos Yet???
                            snort pixi sticks=symptoms-:
                            • txboatpilot
                              • Oct 2007
                              • 1494
                              I just started installing the hardware today....
