Thanks to the generosity of my racing benefactor, Mr. Michaud, I got to build a dedicated P-Sport FE 30 to compliment my FE 30 P-Spec LSH boat.
Borrowing the 1515 1Y & T180 from my Vegas, I decided to go solid & sturdy with the components. The front-mount motor mount Jeff supplies for the FE 30's is super strong so I went with it, although I added a 3/32" ply base for added rigidity. I used a .150 flex with teflon so I can pull the teflon & run a .187 if need be.
Because I wasn't sure of battery/batteries placement, I used 90 degree fittings on the SC to allow room for dual batteries on the side if I need the extra capacity, and 4S 4000 Turnigy Nanos fit beside the SC should I choose to go this route.
[more pictures in following posts]
