What's the best 540 brushless motor for 25" prince answers will be appreciated
  • Matt_1234
    • Jan 2011
    • 146
    Hi everyone, just wondering what would be the best 540 brushless motor for a 25" brushless prince boat? I want it to go as fast as it can as long as the hull handles the speed lol. I also want it to run not too hot. Not sure what batteries I would be running but I was hoping you could tell me that with the choice of motor. And also I don't want to spend to much because I have to sell a brand new 380xl that hasn't even arrived yet. Also sell another 380 and 2x 3cell batteries. So the money I get from that will be for a motor and batteries. Thanks alot answers would be much appreciated even if the motor is too expensive I will take anything into consideration
    Thanks alot
    Matt
  • martin
    • 2887
    If your going for a bigger motor & higher voltage ie 4s 14.8v which i believe is the max to use in this hull youll probably need to replace the esc with a higher amp one as well. Thanks Martin.
    • Matt_1234
      • Jan 2011
      • 146
      well i think the 125amp esc can hold anywhere between 2-7 cell lipo so yer ill just try this one for now then i will upgrade if its crap.
      • martin
        • 2887
        Yes the 125amp esc should br fine on 4s, I didnt realise you had a 125amp esc. Most of the various versions of this hull all be it they use a different name for the boat only fit a 70amp esc. Thanks Martin.
        • Matt_1234
          • Jan 2011
          • 146
          Yeah it should. My mate came up with a good motor choice it's a leopard 2200kv on 2x2cells in series to Make 4cell. When I ran it on 3cell with the 380L motor I thought it was fast but needed more speed so hopefully the leopard 2200kv on 4cell will give me more speed on 4cell without overheating. What do you think??? Thanks matt
          • marko500
            • Aug 2008
            • 861
            Which Leopard 2200kv were you looking at?
            Mark
            • Matt_1234
              • Jan 2011
              • 146
              I think it's this one not too sure my friend didn't send me a link he only sent me the kv !!http://shop.rcboatbitz.com.au/index....roducts_id=381
              • martin
                • 2887
                The Leopard motors are very good also a reasonable price, The 380 motor on 3s would probably give a max of around low to mid 30s mph. This bigger Leopard motor on 4s would probably give around low to mid 40s mph on 4s with a bigger prop Thanks Martin.
                • Matt_1234
                  • Jan 2011
                  • 146
                  Yeah I think that's plenty of speed for a 25" hull! Would the hull handle that motor alright I can't see any reason why not everyone is liking the way these hulls handle so yer what do u think??? Also would that motor heat up much with stock prop it's 35mm in diameter??? Thanks
                  • martin
                    • 2887
                    You would probably see less heat on the smaller 35mm prop than on a bigger prop because their less load so drawing lower amps but the the trade of would be lower speed because of the smaller prop that has less pitch. A friend of mine has one of the various versions of this same hull that he has just put a 540 size motor but only an FSD make motor in & on 4s & he is running on the stock 35mm prop with no problems. Thanks Martin.
                    • CaptPJB
                      • May 2010
                      • 237
                      I plan on using a Tacon 3650 2950kv on 2s or maybe 3s with 120 ESC in similar DF clone hull . Already have the motor in a 25 Rio and it runs great on 2s with 40 or 42mm prop. (I prefer the 40.) 3s a little too much for the Rio hence the reason to go to the DF clone.
                      Great motor for the price
                      • Steven Vaccaro
                        • 8721
                        I race with a feigao 540 6L or 7L with 2s and its very fast. But that requires a 240 esc and 200 amp draw batteries.
                        Steven Vaccaro
                        • martin
                          • 2887
                          The Feigao motors do seem to run a lot hotter than some other make motors. Thanks Martin.
                          • Steven Vaccaro
                            • 8721
                            Not in my boats. Set them up as they are meant to be and they run well. Any motor will build heat if run outside its parameters/efficiency range.
                            Steven Vaccaro
                            • Matt_1234
                              • Jan 2011
                              • 146
                              yeah i rekon ill stick with the leopard 2200kv cause i think its going to be crazy fast and hopefully it wont stuff up using the stock 35mm prop. thanks
