acronyms list
  • Diegoboy
    • Mar 2007
    • 7244
    acronyms list
    I was thinking about some of the new members to the forum and how some of our conversations could get a little difficult to understand with all the abbreviations we use. I'd like to compile a list of them. Here are a few that come to mind. I'll try to keep them in order.
    Please feel free to add, and I'll edit the OP.
    Aft = Back of boat
    AKA = Also Known As
    BB = Ball Bearing
    BEC = Battery Eliminator Circuit
    BJ = BlackJack (Pro Boat model)
    BL = Brushless
    BTW = By the Way
    BUMP = A text response to get the thread back to the top of a forum
    CA = Cyanoacrylate Adhesive
    CC = Castle Creations
    CCW = Counter Clock Wise
    CF = Carbon Fiber
    CG = Center of Gravity (Also COG) :blushing:
    CK = Carbon Kevlar
    CNC = Computer Numerically Controlled
    CW = Clock Wise
    DR = Dual Rate (A switch on the transmitter to allow more or less servo travel)
    ECM = Electronic Counter Measures
    EPA = End Point Adjustment
    ESC = Electric Speed Control
    FG = Fiberglass
    Freq = Frequency
    FS = For Sale
    FYI = For Your Information
    HOC = Hot Off the Charger
    IIRC = If I Remember Correctly
    IMO = In My Opinion
    IRL = In Real Life
    Kv = RPM (revolutions per minute) per volt - Kv (multiplied by) Voltage = RPM
    LHS = Local Hobby Shop
    LiPo, Li-Po, Li-Poly = Lithium Polymer (battery)
    LSH = Limited Sport Hydro (hydroplane)
    LSO = Limited Spec Offshore
    LVC = Low Voltage Cutoff
    mah = Milliamps per hour
    Newbie, Newb = A new person or beginner
    NIB = New In Box
    NiMh = Nickel Metal Hydride (battery)
    OP = Original Post (post # 1 in the thread)
    OSE = OffShore Electrics (The site you are on now)
    OTS = Ooh That Smell
    PCM = Pulse Code Modulation
    PPM = Pulse Position Modulation
    Prop = Propeller
    Prop Wash = The water movement created by a propeller
    RFI = Radio Frequency Interference
    RPM = Revolutions Per Minute
    RTR = Ready To Run
    Rx = Receiver
    SAW = Straight-A-Way
    SS = Stainless Steel
    SV, SV27 = SuperVee 27 (Aquacraft model)
    SW, SW26 = ShockWave 26 (Pro Boat model)
    TBD = To Be Determined
    TFMS = Tune For Maximum Smoke
    TS2 = Top Speed 2 (Aquacraft model)
    Tx = Transmitter
    W/ = With
    W/O = Without
    WOT = Wide Open Throttle
    WTB = Want To Buy
    XTAL = Crystal
  • Jeff
    • 232
    What is IIRC ?
    Jeff
    I try and avoid paste eaters.
    • ReddyWatts
      • 1711
      If I Remember Correctly -or- If I Recall Correctly
      ReddyWatts fleet photo
      • Diegoboy
        • Mar 2007
        • 7244
        Originally posted by Jeff
        What is IIRC ?
        Jeff
        Good one. I added it. Thank you
        • Steven Vaccaro
          • 8721
          Very good idea. I'm considering making a new category to add this and info like post pictures and stuff. A place where people cant ask questions, just go to learn and surf for info.
          Steven Vaccaro
          • SJFE
            • 4735
            DUDE Are you expecting a Harpoon Missile attack any time soon? If so I will be installing P.H.A.L.A.N.X (ciws) on my Jolly Cat. I can't afford to take one broad side @ over 450 knots...LOL
            • Quicksilver
              • Jun 2007
              • 211
              look at that I learned a few, though if you're going to have ECM up there how about EMP, SAM, and ........AARP
              We might need those, EMP's would be very dangerous to our boats, SAM's could hit me when I jump my boat off a dock and we all know AARP is evil. :)
              Aft isnt an acronym(adverb), but you could add more terms for new boats. port, starboard, bow, motor component terms, jet drive terms like impeller, nozzle, stator.....
              wtf
              I just got up I'll think about this some more.
              BOATS CAN FLY AND SHOULD!
              • Diegoboy
                • Mar 2007
                • 7244
                Sorry guys. It was 4:44am I was just throwing down what came to mind.
                • properchopper
                  • 6968
                  re :
                  Here's some from the SAW [Straight-A-Way] racers's vocab :
                  TFMS ; Tune For Maximum Smoke
                  OTS ; Ooh That Smell [ what happens when you do the above ] !
                  • Diegoboy
                    • Mar 2007
                    • 7244
                    Thank you! Added them...
                    • Mich. Maniac
                      Banned
                      • 1384
                      Hey how about the class specs also that are used. P mono what does that mean. If someone could give some detail on classes maybe we could all start shooting to build FOR them if wanted. so far I have just been building for my class (THE LOWER CLASS)
                      • SJFE
                        • 4735
                        You have a point. Why not just say 4S. Voltage defines the classes anyway.
                        • properchopper
                          • 6968
                          If you go to the NAMBA site, click on Resources, click on Rulebook, scroll to Sec 28, pages 5-18 you'll see the electric class specs for hulls [ e.g. "mono" ] and power [e.g. "P"]. I decided some time ago to build my boats to conform to the class rules, so that if I wanted to race, my fleet would fit into an existing class, even 'tho I'm mostly a pond basher/fun runner. Once the racing bug bites, you may find that building your fun runner to fit a class will let you jump in & race when the opportunity presents itself.
                          • FE_Chris
                            • Jun 2007
                            • 764
                            Heck yeah!! I fun run and race my boats! I might prop up or gear up a little more for racing than I do bashing but there is no reason most oval setups can't be fun run IMO. As long as you have lipo cut off
                            • Rex R
                              • 992
                              if 'we' are also defining terminology...how about defining 'hooking'(as in its got a bad hook), prop/chine walking(been there done that:)) etc.
