I got a used nitro miss llumar that I am converting to f.e. Been following a couple of build threads on similar hulls. The motor is a feigao 9xl(approx.1900kv) mounted on an etti motor mount, octura coupler, stock flex shaft. I'm working on a speed control and battery placement seems to be the big issue on this hull. Using a jr servo mount and stock proboat servo for now. Here are a few pics.
Miss llumar nitro conversion
You runin 2 2s packs? Can you place them inside the cockpit in a "<" shape on each side of the motor?FE BOATING: Less like a hobby and more like an addiction! -
Thats an interesting rudder. Come with it? I did a miss bud coversion many moons ago with an Aveox system. Ran pretty good but the inside is so darn tight I just couldnt stand it with my big mits. I put my speedo in the servo box to keep it protected. Since I was using nimh cells I didnt care if they got wet. Very easy to dry out with a heat gun! Keep us posted. Looks gooooooood!
JohnChange is the one ConstantComment
JohnComment
Really? I missed that build. I'm trying to keep this one simple and not mess with the stuffing tube. Already epoxied the mount in place. Thanks for the info. I'll have to search for that thread.Comment
I dont think you have a choice with the batteries..... lol Keep your cog at 1-1.5 inches from the back of the front sponsons if you can.FE BOATING: Less like a hobby and more like an addiction!Comment
Here is a shot of the one I built for my dad.Attached FilesFE BOATING: Less like a hobby and more like an addiction!Comment
I did kinda the same thing but it was a 2S2P setupAttached FilesComment
I was itching to get her wet so I just taped the piss out of it. Did seal permanently the back hole where the "turbine" is tho.FE BOATING: Less like a hobby and more like an addiction!Comment
sweet! I love these hulls, best looking one out there - for scale.
Yeah my thread was a parallel build with Bustit, so you gotta run through it all.
I did a little work on it, stiffening and balancing. added a wire drive - didn't like that monster stuffing tube - and was determined to get the weight as far forward as possible. With motor in cockpit and batteries almost into the sponsons, I still had to add ballast to the tip of the sponsons.
I be watching!
vid 1
vid 2"Look good doin' it"
See the fleetComment
