Tunnel wing operated by a gyro/servo , still in the drawing board stage. What i am trying to do is push a H&M Maritimo to its limits . Anyone had a go at this, i know the full size boats use to have them but where banded . Thanks Bonewar
I think that even if it helps the boat stay in the water longer it's an achievement, that's what one needs to get the extra few mph in... go ahead and try it man!
It's worth trying...........
Big round of applaus for everybody who dares to think out of the box.
As far as I know it hasn't been tried on a Maritimo.
THANKS FOR THE REPLIES GUYS, My take on this is , when the hull gets to the level where the running gear is at its peak performance and no more speed can be achieved buy the set up , This is when the wing will come into play , just like UB said the extra mph is what I'm trying to achieve on top of a very fast setup. CRAB STICK mate i do not know much about gyro's , what would be the fastest and best for this idea?? GERWIN I'm shaw you could buy a digital servo that would be fast enough for it to work. So anyone with ideas on the right gyro/servo to use in this application?? THANKS PEOPLE BONEWAR
SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
I would go for a futaba gy401 and a futaba 9650 servo. If you make the actuation system like a cam and actuate it with a horn on the camshaft shouldnt load the servo up much at all, you could I guess go for a larger fast digital servo for a bigger boat
Got another idea, How about putting a trim tab on each of the spoonsons transom and having them run be the gyro/servo , Or just using the TX to control the height of the tab( manually)? Or maybe using a channel mixer to work both of the tabs? Any ideas here are very welcome. Thanks people Bonewar
Great idea, I know of a gas boat that has a mix to control full down trim tabs in a turn and they come up in the straights. From my limited knowledge in fluid dynamics I have read that hydrodynamic drag is about 10 times that of aerodynamic drag on the same surface area creating said drag (if that makes sense), I think if you can adjust the hulls attitude via aerodynamic drag then you will maintain more speed. Sounds good on paper anyway.
Dude, great line of thinking. From running my cat with the newly designed and installed tunnel flap, I would rather have control with a third channel the attitude of the flap than a gyro. Not sure what your end goal is, but I think that a good point was made about the quickness of response time needed to be self correcting. More realistically, I would like to have a servo adjust my tunnel flap as water conditions change, wind direction change, turn radius changes and as I add more voltage.
In the end I would imagine you would need to build a pretty big one to have the kind of action you are looking for. Don't misread me: I am not saying it won't work, just expressing my intuition. Personally, I would stick to the tunnel and not mess with the transom tabs; I think the air under the hull is the best place to play (along crabsticks line).
I'll be watching to see how this turns out, verrrrry interestink.
I've been thinking about this for awhile also. My thinking is a wing on the bow between the sponsons. The pivot point would be set back on the wing a little not right on the leading edge. By changing the angle you could either pack more air into the tunnel or deflect some up over the deck. I was thinking like Jesse said to adjust to water and wind conditions more then to be self correcting. I realize this won't prevent blowovers but more to adjust ride attitude. Mark
