Slim that looks like the remains of some over cooked takeaway food
After reading your comments I guess you have one choice. Drill two more holes in the flex shaft end of your coupler and then tighten all your grub screws up as tight as you can. I have been known to get a real bend in the Allen Key while doing the screws up. Use Loctite on all your grub screws on the drive shaft from the motor back to the prop nut. I have never had a prop nut come undone but I have taken note of what Viking said and will use a little Loctite there also from now on.
You may have some handling issues with a flat CF turn fin. I have a flat one on one of my Xs 2's and it does not turn left well without sitting the boat on the water, prop side up.The other Xs2 has one with a curved bottom and it turns both ways well. Try to get used to going clockwise around your pond and it should be ok. BTW I have used and recommend Vikings wheel collar idea.
Slim keep asking question as we are both learning. I have learned from Vikings comments (thanks Viking) and so we all benefit from each others questions and answers.
