Hi all,my next build will be the Thunderbolt cat.
Just waiting for the hull, should be here in few days.
Since the 58" Navaho twin build I did few years ago I have really started to like outrunners and most likely will use these in this build also.
I am on relatively small budget on this build also, but will get a bit better esc´s .
Now I am still thinking if the 180A seaking would be good enough or maybe the HV version would be better (this), will see kind of depends of the motors and batteries but I would like to hear your opinions.
I belive that 6s and these 1250kv
or 12s and these 530kv
Both have quite good power (3,9-4.25kw ) compared to the 910kv 3kw ones I have on the navaho. The H37404 I used on the Navaho are still working well and they are one option to use on this build also( these ) .
The Navaho is about 50mph boat right now with pretty warm motors ,trying to build this smaller cat with faster speed and long run times in mind. -I´d say about 60 mph is the goal but if it ends up going faster then that is no problem...
So what do you think of my plans and what would you change?
Thanks for looking,
-Pate
Thanks for looking,
-Pate
