Genesis Build
  • dddmx3
    • Mar 2010
    • 233
    Genesis Build
    Starting a 37in Genesis Build!
    Drive: Got it! $28 - .187 Flex (3/16)
    Coupler: Got it! $20 - 5mm to .187 (3/16)
    Drive Dog: Got it! $6 - 3/16 Drive Dog
    Mounts: Got it! Made them myself!
    Motors: $150 - CC1512's 1800kv
    Hull: Got it! $135 - 37" Genesis Bare Hull
    Esc's: $180 - 2x Turnigy 180a
    Power: $100 - 5s2p (10-cell)
    Props: $26 - Octura x442
    Hardware: $18 - Center mount rudder
    Hardware: N/A (Struts)
    Servo: $27 - Hi-Torque Traxxas
    Total (so far) for build: $690
    Total (so far) bought: $339
    Key:
    Got it - This means item has been purchased.
    Need a good setup that could get me in the 60-70 range.
    I put up some links from some rough ideas I got earlier.
    After all is said and done, more is said than done.
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    • Make-a-Wake
      FE Rules!
      • 5557
      Twin 4082's on 6s with two T180s is alot of weight...........and overkill for 50+ mph. Stock genesis runs 40 on 4s with one 540XL.
      Twin Feigao 540 13L's can get you 50 on 4s..............twin 540 8XL's would be a real hoot.
      • LarrysDrifter
        Big Booty Daddy
        • May 2010
        • 3278
        • Make-a-Wake
          FE Rules!
          • 5557
          Larry is spot on that the Leopard 3674's are more efficient, run cooler and offer more power, Twin 3674's will get you 60+........................
          • dddmx3
            • Mar 2010
            • 233
            The 3674's arnt on ose...
            Going with 6s btw
            • Rumdog
              • 6453
              thw CC 1512's you listed in post#1 are the best option. 2600kv on 4s, or the 1800 kv on 5 or 6s
              • dddmx3
                • Mar 2010
                • 233
                1800kv on 6s would be obviously be faster but what about runtime? Also seaking 180's would work right?
                • Make-a-Wake
                  FE Rules!
                  • 5557
                  The T180's will work but are not needed..............twice the weight and these 120's will handle the 1512's or these Leopard 3660's i found that will be great for 6s.....60+
                  http://www.offshoreelectrics.com/pro...=hef-sword-120
                  • Rumdog
                    • 6453
                    I'd go with 180s. Esc weight isn't going to slow you down. It's better to have headroom.
                    • dddmx3
                      • Mar 2010
                      • 233
                      Alright I'll go with 2x 200amp swordy's... Any ideas on what kind of stingers I could get?
                      Edit: Nevermind I'm going to machine my own stingers (:
                      • dddmx3
                        • Mar 2010
                        • 233
                        my friends on vacation when he gets back next monday ill be able to start making the stingers!
                        • Diegoboy
                          • Mar 2007
                          • 7244
                          • dddmx3
                            • Mar 2010
                            • 233
                            Why not get a swordy 200? It's cheaper plus more amps? What am I missing?
                            I see it has a bec...
                            • Diegoboy
                              • Mar 2007
                              • 7244
                              That is an excellent option, I agreed to the "headroom" comment
