also what size capacitor is good ?
Why do some people solder a capacitor to their esc ?
In simple terms - particularly when using long power wires (over 8" total), adding caps helps protect the ESC from ripple current which can cause ESC failure. The "capacity" of the caps depends. You want a cap with more voltage than your ESC maximum (like 35 volts for a 6S controller), good for 105*C, and equal to or greater than 500 uF. Sometimes two or more are added.
.ERROR 403 - This is not the page you are looking for
You can also purchase an already assembled cap board. They get soldered on to your battery wires on your esc.? WHAT RULES?
I added these two 1000uf 35v caps to the 3 existing 1000uf 35v's on my T180. Caps went down in temp significantly.Attached FilesNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
For those big jobs.Comment
Concerning capacitors:
The rule "a lot helps a lot" is true and the reason for additional capacitors was already explained. Therefore I just want to add a hint: Put the caps as close to the controller as possible, this will increase performance. If the cables between capacitors and controller are too long, there won't be a positive effect.
Best regards,
ManuelComment
