Results 1 to 8 of 8
Thread: Blackjack 29 v3 6s runnin hot
    Mar 2018
    IN
    64
    Default Blackjack 29 v3 6s runnin hot
    Just got my upgraded flex in along with the stock prop balanced and sharpened. Also put the swoop lines in.
    Running 6s, the motor after 2 or 3 passes Is hot. Like I can hold my finger on it for 5 seconds.
    I'm assuming I need the 1650kv motor?
    Sent from my SM-G955U using Tapatalk
    Oct 2016
    pa
    476
    these always run hot .get a temp checker ,what feels hot to you maybe actually be acceptable .only way to know is with a temp gun .they are cheap .
    but yeah these boats run hot .a lower kv motor would be good .but a bigger can motor with lower kv would be better .
    do you watch the water outlet to be sure the water is flowing?
    you can try opening up the water inlet in the rudder a little .theres a video on youtube showing you how .
    Mar 2018
    IN
    64
    Water does flow out of it. So it is working. Not sure how well?
    Apr 2017
    QL
    1,038
    2000 kv is too high for 6s. that motor is more suited to 4s. unless your doing SAW you shouldn,t go higher than 1500 kv,s on 6s. also your motor cooling line is back to front. inlet at bottom not top.
    Mar 2018
    IN
    64
    Well damn. I read on here all over that it does run hot. But I didnt think it ran this hot.. I cant even run a whole pack through it.
    Jan 2013
    Ga
    1,358
    Mar 2018
    IN
    64
    I know. I know that's the next upgrade. What water jacket
    Jan 2013
    Ga
    1,358
