I was just about to order some 6 cell packs..I think I will now wait a few weeks to see how this pans out! Mike
http://www.hobbycity.com/hobbyking/s...8&ParentCat=85
holly crap.....
DJI Drone Advanced Pilot
Canada
Just ordered... Hope they are as good as the label
They are just now catching up with the Hyperion G3's that have been out for several months now. Hyperions are more but available and warranteed here in the states.
I give a great discount to the OSE guys.
Mini Cat Racing USA
www.minicatracingusa.com
I just saw those Nano packs..
what's the big difference with these new cells?
They are not on our site. We will be stocking just the 3S 2100 25C's for use in our mini boats. All other batteries are special order. Just email what you need and we'll take it from there.
Mini Cat Racing USA
Probably need to set the LVC even higher now as they will most likely totally discharge their capacity before hitting 3.2-3.4 Volts. Gonna take some testing to still leave the recommended 20% capacity in the packs. That's if you drive by the LVC.
Cheers.
Paul.
https://forums.offshoreelectrics.com/...hp?albumid=319
https://forums.offshoreelectrics.com/...hp?albumid=320
Huh? Where did you get that logic? They hold their capacity even longer. Why do you think they would discharge more quickly and why would you think you need to set the LVC higher? That doesn't compute.
Mini Cat Racing USA
I think he's saying that the voltage won't lag as much under load, meaning that they may run longer before hitting the LVC. The only time I've had an issue with that happening is if the motor is pulling more amps than the packs can supply. Which def. shouldn't happen with packs rated like these, unless you're severely overpropped.
Maybe I read it wrong. I thought he was saying the voltage was going to drop quicker. Still not sure why you would set the LVC that high.
Mini Cat Racing USA
Well ya know, us florida crackers ain't got much o them technical minds to wrap round such equashuns
Mini Cat Racing USA
hmmm, maybe! I've never experienced that. But with the higher C ratings, that should allow more amp draw and help prevent it I would think.
Mini Cat Racing USA
Yeah, sounds more like a bad ESC than a battery problem.
Mini Cat Racing USA
Yep, also the only real reason the lvc would kick in early is if the cells can't [rovde the needed amps. Voltage drops, LVC kicks in.
Man, do I need a spell check.
ESC is still fine, and LVC cuts in nicely when im not trying to draw stupid amounts of amps from it... I just think on this particular occasion I drew too many amps, too quickly and the LVC didn't cut in right away.
sounds like a battery issue
the LVC is built to save the batteries and if its not keeping up its not working right!
Sorry.
What I was trying to say is that they will hold the voltage higher under load & that if the LVC is set to say 3.0 V They will totally discharge their full capacity & sometimes even more before the voltage drops to the LVC & you've over discharged your battery as there will not be around the 20 % capacity left.
Even when set at 3.2V my 40C packs will have only about 10% or 15% left if I let them hit the LVC (which I try never to let happen)
So these Higher rated Packs WILL hold their voltage Higher for longer & the packs Will most probably over discharge before they hit an LVC of 3.2v or maybe even 3.4V Remember over discharged is with less than 20% capacity left in the pack.
I've put back 5480mah back in a 40C 5000mah pack once when I ran it until it hit a 3.0V LVC. A 20C pack wouldn't allow that to happen.
as its voltage would sag earlier.
As a rule I try to bring the boat in before I hit any LVC.
Hope this helps a bit.
Paul.
