Page 1 of 2 12 LastLast
Results 1 to 30 of 36
Thread: Ideal setup for TFL Cheetah
    Nov 2019
    NC
    79
    Default Ideal setup for TFL Cheetah
    Hello all. Recently purchased this beauty that was never put to water due to hull damage in the gelcoat from its stand. She was repaired at a local boat shop. She was put together by Sandy at TFL. The escs, gps and receiver are mounted forward with the batteries aft. Please critique and offer input. Havent put her to water yet, she is getting a new wrap. The ESC are seaking 180a the motors are SSS 4082 2000kv (owner said 4092 but measuring the can seems to be 4082) Appreciate any advise on layout help.
    Apr 2017
    QL
    1,038
    looks great. just be carefull with the power you have inside the hull as the Cheetah cat hulls only have a desicated top speed before blowing over. we have some of these hulls in our club and fitted with a single motor around 2200 to 2400 kv,s on 4s., there certainly quick enough .
    Nov 2019
    NC
    79
    Are those twin SSS 4082 2000 kv too much for it, or can she handle more? I planned on getting some 6s once I get used to it and dialed in on 4s.
    Apr 2017
    QL
    1,038
    the 2000 kv motors are fine for 4s but not really suitable for 6s . normally a maximum kv of 1600 is safe for running a 6s setup in oval trim. just see how she perfoms on 4s for now as i am sure you will be quite happy with results. try 447 props and check temps after short runs.
    Apr 2017
    QL
    1,038
    search Cheetah Hull on this forum as you will find alot of info with the twin set ups.
    Nov 2019
    NC
    79
    Thanks brother. Really appreciate you taking the time to help the FNG
    Apr 2017
    QL
    1,038
    Thats ok mate, this is what the forum is all about. normally there are more guys on this site that are very experienced in advice.
    AZ
    8,010
    What are your speed goals for this hull? I ask because as stared above, the Cheetah is speed-limited due to its design. It is a great oval racer, but cannot reliably achieve the straightaway speeds that the narrower, more scale-like hulls can. Doesn’t mean it isn’t fun, it is, but putting excessive power into the hull just adds cost, not speed.
    Nov 2019
    NC
    79
    I was hoping 70s if at all possible on 4s per side stable. The guy I bought it from said it is a 6s setup according to Sandy from TFL but not sure if those 4082 2000 kv motors are adequate?
    AZ
    8,010
    Those motors are more than large enough for 4 or 6S, the Cheetah is not a large hull. Reaching 70 mph is possible on smooth water but you may need an air dam and a forward CG.
    You will need props with at least 3” of pitch to approach 70 mph on 4S, a bit over 2” pitch on 6S. The Kv is pretty high for 6S, you’ll be around 40,000 rpm on the water and it will be easy to overheat if you over-prop a bit too much. Are you looking for zip-zip passes at high speed, or longer run times and general sport boating?
    Nov 2019
    NC
    79
    I wish I knew more about the CNC props on it. All I know is they are 40 props. Zip Zip passes would be nice but I dont think this is the hull for it? Im looking to start a club in my area and maybe get enough interest from the local community, marines and navy to get some official racing down here in Jacksonville, NC.
    AZ
    8,010
    Cool
    If you want to oval race the Cheetah, then 70 mph isn?t very realistic. In rough race water it will blow over, but so will most similar-sized hulls. Not knowing much about the props it is difficult to estimate speeds on 4S, assuming they are 1440s then the pitch is 2.2?. This would give speeds around 50, a bit low but for a new club with guys running RTR cats it may be a good place to start. If you are substantially faster than the other new guys they may become discouraged. Just a thought from a guy who helped start up several clubs...
    Nov 2019
    NC
    79
    All valid points! But in the famous words of Ricky Bobbie, If you aint first, you're last! Lol kidding. Appreciate all the feedback gents!
    Apr 2017
    QL
    1,038
    also you must finish to be first.
    Mar 2017
    VI
    371
    https://m.youtube.com/watch?v=nFl9G7-6Gk0
    This video shows the potential of the cheetah.
  16. #16
    Jun 2010
    Mi
    738
    Quote Originally Posted by Speed3 View Post
    76 mph? any idea of the setup?
  17. #17
    Nov 2019
    NC
    79
    Today was able to take her out for the first time and noticed this. Didnt hit anything and took it easy and noticed it while wiping her down. Thoughts? What should I do? 20191119_165454.jpg20191119_165547.jpg
  18. #18
    Mar 2017
    VI
    371
    Quote Originally Posted by larryrose11 View Post
    Twin Leopard 4074. Not sure of the kV or props. And 6s.
  19. #19
    Nov 2019
    NC
    79
    This is a TFL 34 Cheetah. First time out on a pond and taking it easy.
  20. #20
    Jul 2016
    4,117
    If it were my boat, I would pour a mix of epoxy resin and chopped carbon fiber into both tips to help secure the two hull halves across that portion of the seam. Hopefully the chip is just a defect in the gelcoat at that portion of the hull and not a bad seam joint.
  21. #21
    Nov 2019
    NC
    79
    Thats a great idea. Thank you fweasel!! im starting to think bad gelcoat. If you read above, the guy I bought the boat from got it from TFL and he had it in the wooden stand and it caused this from pressure. The stand was super tight, I had to sand it down. 593917272(1).jpg
  22. #22
    Nov 2019
    NC
    79
    Alright gents, my initial plans of a wrap fell through so decided to paint. Go easy, this is my first paint job lol. Went with a last minute color change and some design using color shift paint in purple sunset. I had a little paint bleed in the front from last minute change but I can fix that. What do you all think so far? Decals and clear will be coming soon. Thank you all for your input and help.
  23. #23
    Nov 2019
    NC
    79
    Got her decals on. Ready for clear.
    What yall think?
  24. #24
    Nov 2019
    NC
    79
  25. #25
    Jul 2016
    4,117
    Looks really good. Love the purple on white.
  26. #26
    Nov 2019
    NC
    79
    Thanks fweasel. Its color shift testors. Changes blue to purple. Wanted a clean look.
  27. #27
    Nov 2019
    NC
    79
    Does anyone have guidance or can point me on how to make the conversion to a single flex cable or do I want to stick with the two peice shaft it came with?
  28. #28
    Nov 2019
    NC
    79
    Finally got her finished, ready to throw her hardware back in. Reinforced hull with some cf and west systems marine epoxy to include the tips thanks to guidance from everyone here. Not the best paintjob but it's my first boat after the traxxas.
  29. #29
    Dec 2013
    138
    Default Almost ready to try.
    Just finished painting mine. Have to put the parts back in for a maiden.
    Dumas Air Boat OS 25 nitro, Dumas Air Boat Brushless, Midwest Lobster Boat, AQ Lucas Oil Cat, Dumas Hot Shot IV Proboat outboard, Delta Force Cyber Storm 33
  30. #30
    Nov 2019
    NC
    79
    Nice! Show us some pictures sir! Here is her maiden runs.
