Page 2 of 6 FirstFirst 1234 ... LastLast
Results 31 to 60 of 162
Thread: Mah resitrictions
  1. #31
    Oct 2009
    MI
    6,192
    Yeah that's interesting Larry. I've been told this for years but it's not really true. You have to stick to the safety rules. The book says that failure to comply with the safety rules may result in a loss of coverage. Paraphrasing. No where does the book say "You must comply with every letter of this document or you will not be insured". I've been told repeatedly "Well, they expect us to follow our own rules". Expect? Good luck with that in court. If it's not on paper it didn't happen. Ever see cats and monos sprint together? Guess were uninsured at that point. Nonsense.
    Cell counts and battery specs aren't in the safety rules. If the insurance company wanted to jam that "you weren't following the rules" thing down our throats then no event that I'm aware of since lipo was introduced would have been covered because no event that I'm aware of has ever truly tech'd the mah's. You could read the label but who knows what's under the label if you don't do a full discharge and then a subsequent recharge. Then do you discharge down to 0% before a refill to absolutely sure? If we were getting all lawyer'y, "Where's the documentation proving that you checked it?"
    Checking them with absolute certainty should only take an entire day for tech for each day of racing. The only thing I check is voltage. I don't think anyone escaped scrutiny at the Cup last summer. If I missed someone I apologize. I'll be sure to check all of your crap this year. We've relied entirely on good faith since introduction of Lipo.
    The whole restriction thing was an attempt to appease those that were convinced Lipo would spell the end of racing. Same response that brushless motors received. "RACING IS RUINED! WE'RE JUST RACING WALLETS NOW! THAT'S IT! I'M OUT!"
    Still not sure how to address the twins thing. Larry's 6s3p twin Q cat scenario is pretty realistic and would likely come in under weight. Not sure it would be drive able but it is possible. We're planning to test a 20k single Q cat for Atlanta. See if that works. Weight is under easy.
    John, I'm not sure it matters what the CD states on the flier. If a guy shows up with cells that don't have labels at all........ how does the CD know anything more than the voltage? Hmmmmm, those look like 5600 2p to me. The sketchy part would be the legitimacy of the results. For instance, one could argue that a national championship awarded to a racer whose cells were not dumped and recharged to verify compliance with the MAH restrictions is not legit. Ridiculous but you could make the argument.
    Every record run is tech'd for compliance with the rules.......accept the mah restrictions because to do so is a nightmare. I've signed some record applications. I've not checked the mah. Only voltage. I doubt that the SAW guys are doing a complete discharge and recharge.
    Noisy person
  2. #32
    On
    7,279
    The only reason I brought up the CD/Flyer thing was if someone who had some 6000 packs and they wanted to run in 2P
    they could (like P-Mono/Cat) without having to buy new packs....
  3. #33
    On
    7,279
    I think I'm going to re-label all my packs as 4S Flux Capacitors.
  4. #34
    Dec 2011
    On
    561
    Didn't the mah limit restrict the size of prop you could spin in off shore and the roundy round? now more mah means bigger wheel, go faster and so on. next will it be length and weigh restrictions changed to hold more batteries . now safety really becomes an issue. instead of an 18lb T- boat doing 65mph in the roundy round, now you may have 30lb boat doing 75plus mph.... and the wakes would be massive with 4-6 T-boats, yikes !! just my .02, race on
    Cheers, Jay.
  5. #35
    Oct 2008
    CO
    9,488
    are the 2 lap and SAW runs held to the 10,000mah limit in P and Q classes ?
    or are they allowed to run more ?
    thanks
  6. #36
    Oct 2009
    MI
    6,192
    Supposed to be. I don't think the SAW guys typically carry the max.
    Noisy person
  7. #37
    ON
    2,918
    Quote Originally Posted by Doby View Post
    John
    If they had two 2S - 6,000mAmp packs, there is NO problem running them in series, you end up with a 4S1P - 6,000mAmp pack.
    This is still under the MAX limit of 10,000mAmp's on board.
    If you had two 4S- 6,000mAmp packs, and connect them parallel, you end up with a 4S2P - 12,000mAmp pack - NO -over the MAX -10,000mAMP on board.
    If you want to go this way- I could sell a my Offshore Motors, and 5,000mAmp batteries and buy all 6,600mAmp packs, then I could just run my oval setups in Offshore.
    This way also my oval setups will run faster seeing that the output voltage under load would be higher with the higher capacity packs.
    Larry
  8. #38
    Ga
    5,267
    "I don't think anyone escaped scrutiny at the Cup last summer".
    I know Don and I were checked frequently. We were starting to get a complex. lol I think the T mono was checked before every heat.
    Edit: It was as it should be, I'm not complaining!
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  9. #39
    Oct 2009
    MI
    6,192
    I know Doug. I knew what you were running. I didn't want to hear any BS later about Smock this or Smock that. I'm sure you already know this but I wasn't trying to catch a single person cheating. I was preventing others from making accusations later. It wouldn't have come from anyone at our race. It would have come from people NOT at our race. The usual sources.
    I checked Einstein and PAGS about 86 times. Fireball got a bunch of visits too. I tried to accost everyone at some point. Probably skipped the kids boats.
    Noisy person
  10. #40
    Ga
    5,267
    Oh yeah I "get it" Terry. Not to catch someone cheating, it's to prove they're not. I appreciate you being on the front end of it!
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  11. #41
    ON
    2,918
    Doug
    Terry, Fred & the MI gang run one of, if not the best and fairest races in North America.
    Larry
  12. #42
    On
    7,279
    John
    Larry
    Thanks Larry, but I've been doing math for a few years now and already had that figured out...
    I'm just saying that if some newby, like a Smock or Don H are entering their first race with their P Mono and want to join in on the craziness with their 2, 4S 6000mah packs to run in parallel, could they still be allowed to run if the race waiver allows a bit extra capacity? I'd hate to think some folks would be turned away for a few extra mah. Unless of course its for a formal record of some sort.
  13. #43
    On
    7,279
    Doug
    Larry
    The're a bunch of bums...Terry needs a calculator to figure out a 4s packs voltage.
  14. #44
    On
    7,279
    Checking Kanadians packs voltages is a waste of time, we're the most honest people on the planet. Southerners though...well that's a whole different ball game....they've always got a extra cell up their sleeves.
  15. #45
    ON
    2,918
    John
    If it is club race - No Problem
    If it is a NAT's or MI Cup size race - NO WAY
    To allow one person the extra capacity is a big advantage to that person.
    Higher capacity cells give higher voltage under load.
    To put it in the race flier, means that everyone else has to buy new packs to compete.
    It is easer for that one person to borrow or buy legal packs for the race.
    Larry
  16. #46
    Ga
    5,267
    That may happen this year. My old 5000s are letting go and are being replaced with 5200s.
    Out of curiosity, what's the procedure for batteries that have had the original labels / heat shrink removed?
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  17. #47
    On
    7,279
    Quote Originally Posted by Doug Smock View Post
    Personal integrity.
    Of course anyone who thinks a couple of hundred extra Mah capacity is going to win them a race is delusional.
    Perhaps the rules need to updated to state that only factory labeled packs can be used.
    I have both 5800Mah , 4200Mah and 5000Mah packs that could be used on 2P setups...oh the horror...there's a possibility of over 10000mah capacity. I also have some HV packs (but no HV chargers) EEEKKKKK!!!!!!!!. Guess Terry's going to be busier than a one armed wall-paper hanger at Michigan this year....checking voltages, capacities, labels, underwear color, etc.....
    Just another reason NAMBA and IMPBA needs to have a group hug and get their collective *!***!***!***!**z together on a standard set of rules for FE.
  18. #48
    Mar 2009
    OH
    1,585
    How is Canadian voltage checked? Is that USA Voltage or Canadian Voltage? I get so confused with the metric system.
  19. #49
    Ga
    5,267
    lol Howard.
    Doby, my Kanadian friend. I understand integrity.
    But what about the guy that buys legal batteries with the paper labels that struggle to outlast a fart in a windstorm? Or the guy that removed heat shrink to dry out legal packs that have been wet? There are legitimate reasons why packs may not have the original data on them.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  20. #50
    Oct 2008
    CO
    9,488
    lol Howard.
    I agree, this is a good question ....
  21. #51
    ON
    2,918
    Doug
    If you have to re-shrink your packs-- Use clear shrink
    Even the packs from China have electro printing on every individual cell, stating the capacity.
    This now can be read through the clear shrink.
    Larry
  22. #52
    On
    7,279
    lol Howard.
    Back to that integrity thing.......
    Screw it...easier to switch to gas/nitro.
  23. #53
    Ga
    5,267
    It was a hypothetical question Larry. But perhaps it should be addresses before it becomes a problem for some poor guy that has traveled 12 hrs. to a race.
    FWIW the GP and Revo packs I tossed last year had no data on the cells unless it was turned in.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  24. #54
    On
    7,279
    That's exactly what I was getting at.
    Is he going to be turned away for the sake of a few Mah?
    To more or less quote some schmuck that's on here quite a bit..."they're only toy boats fellas"
  25. #55
    Ga
    5,267
    That's not an exact quote, but close enough. lol
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  26. #56
    Oct 2009
    MI
    6,192
    Haha. You guys realize that this was the exact motivation for me having asked the question?
    Some NAMBAnians are actually racing at Legg this weekend. Maybe we'll get some more thoughts after.
    Let's not get bogged down with how the rule IS and focus on the truth. The truth is that there is no reason for them to be different. That's the collective hug John was talking about. Like I said, I race both orgs.
    Maybe I'll just write a proposal. On paper I'm D2 director again with Fred retiring.
    Nobody has sited a reason the limit should still be there. We just need some smarter way to deal with twins. That could get out of hand pretty quick.
    Noisy person
  27. #57
    Ga
    5,267
    Yes and I noticed some of those paper label packs in one of the boats. I sure hope for records sake that they could still read the capacity on them.
    I'm confident that the issue is in good hands.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  28. #58
    Oct 2008
    CO
    9,488
    Thumbs up
  29. #59
    Oct 2008
    CO
    9,488
    Thumbs up
    exactly.. I have several 5100mah and 5500mah 4s packs
  30. #60
    ON
    2,918
    Terry
    What about the HV Cells they are way above 3.70V nominal.
    Larry
