Page 1 of 3 123 LastLast
Results 1 to 30 of 80
Thread: My TFL Pursuit coming up to speed.
    Feb 2017
    na
    726
    Default My TFL Pursuit from 63 to 79mph
    Maiden Run on 6s using a $37.00 Hobby King motor, Turnigy ESC, and a Octura Prop (cause it hasn't learned it's abc's yet) This is a FUN boat and I see nothing but good things to come in the future with it.
    https://www.youtube.com/watch?v=M-6mVcf1gsg
    Feb 2017
    na
    726
    Default TFL Prusuit hits 67.1mph on the second run.
    The second run I got 67.1mph after a few tweaks still running the same setup as above.
    https://www.youtube.com/watch?v=c6LzeczBhAE
    Feb 2018
    PA
    330
    Very impressive.... Nice work..
    Feb 2017
    na
    726
    Thank You!
    May 2014
    636
    Which HK motor?
    Which ABC prop?
    Ron - The Villages, FL
    Feb 2017
    na
    726
    Quote Originally Posted by zooma View Post
    Which HK motor?
    Which ABC prop?
    The motor is an old Turnigy 3674 2000 I had in my parts bin and a Octura prop that has been massaged on by Chris it wasn't an ABC prop.
    Oct 2009
    MI
    6,192
    Still love my Pursuit hulls. They just go where you want them to.
    Noisy person
    May 2014
    636
    Quote Originally Posted by MADRCER View Post
    Wow. 2000kv on 6 cells. I would think you would smoke either the motor or ESC. I realize that you are only doing sprints, so that might be the key to success.
    Aug 2010
    uk
    2,887
    delete.
    Feb 2017
    na
    726
    Yes sir they do.
    Yea, no heat racing with this setup...Just plain ole having fun boatin LOL! I've been beating up a lot of the Dynamite 3831's over the past year or so and I haven't burned up one yet on 6s, but I do make sure cool down laps are frequent and the props aren't too large. That's what I was going to put in this boat but the Turnigy had a showed out in a few boats in the past so I decided to try it in this one. A 3831 might go in eventually just to see what it can do.
    Aug 2010
    uk
    2,887
    Yes sir they do.
    My bad Martin, you're correct I just looked. My 40mm is a 2000kv and the 36mm is a 2200kv.
    Have you also run the 40mm 2000kv motor in anything at all (4074 I presume ), as I was interested in how the Turnigy 4074 - 2000kv motors ran as well.
    Apr 2011
    tx
    1,284
    Now where to pick up a new pursuit hull and hardware?
    white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
    Jan 2013
    Ga
    1,358
    Apr 2011
    tx
    1,284
    Thanks Jim. I’ve seen that but 279 seems high for a pursuit hull and hardware.
    Probably going to end up buying one there but used to buy them for 200 delivered.
    Guess the game passed me by while I’ve been gone.
    Jan 2013
    Ga
    1,358
    Yeah. Seems like HK is getting away from boats or something they don't have many boats like before
  16. #16
    Apr 2011
    tx
    1,284
    I noticed that. Hadn’t looked there in some time. They don’t have much.
    Think I’ll build a DF
  17. #17
    Apr 2017
    QL
    1,038
    Hobby King now have bugger all boating gear. think there going bad.
  18. #18
    Feb 2017
    na
    726
    Default TFL Pursui hits 70.4mph with Octura prop
    With this run I officially put anther one of my boats into the 70mph club (with an Octura prop). Not too bad for a $45.00 motor from Hobby King. I really need a good rain to wash the trash out of the lake because I hit a piece of a limb on my first pass and almost made the rudder breakaway from the mount. https://www.youtube.com/watch?v=8bHW2gbL2VI
  19. #19
    Apr 2011
    tx
    1,284
    I was lucky enough to find the buyer of my old pursuit that I built about 6 years ago.
    Boat need some work but still has all my custom setup inside. Needs a little body work but that’s no problem.
    I was able to get it to 61mph on 4s2p back then running a castle 1515 2200kv swinging a m645 prop. Still have one of those motors so I think I’ll start there.
    Here’s it running back then. Think this was about 50-55 mph run on small pond.
    https://youtu.be/c_0Nw_g5PDo
  20. #20
    Apr 2011
    tx
    1,284
    Btw Mad, that thing is running great. Can’t believe that hk motor is holding up. They must be a lot better than they used to be.
    I can remember blowing those things up on first runs back about 6 years ago.
    Once I get mine back in the water I may try a 5s run to see what it can do. The math says 68mph or so.
  21. #21
    Feb 2017
    na
    726
    Quote Originally Posted by stadiumyamaha View Post
    Nice!
    Thanks! Keep us posted!
  22. #22
    Apr 2011
    tx
    1,284
    Very cool, I didn't know Dynamite has a version of the 1515. Good to know as Castle is only making a sensored version of it now. Its always been one of my favorite 4s batts. Its a torque monster.
  23. #23
    Apr 2017
    QL
    1,038
    you don,t need to use the sensored plug on the castle motors if you don,t have a sensored esc. the Dynamite motors are too expensive for what they are.
  24. #24
    Jan 2016
    1,464
    I really liked the Pursuit and I really miss mine. I decided to do some hull reinforcement and put a new motor and esc on mine and went out to test it but I forgot to put any floatation inside. I flipped it in the middle of the pond and I couldn't reach it with a fishing rod. I thought about swimming for it but this isn't the pond in my backyard and there were bigger alligators in there. So all I could do was watch it go down. The nose did stay up for a bit and if there would have been some wind it might have pushed it closer to shore but it was so calm that day. It finally sank.. .bye bye. Now, seeing yours brings memories and it's making me want to get another. lol. .maybe someone wants to get rid of one? Nice run on your Pursuit Mark. I'm pretty sure you can get more speed out of her as she seems to run smoothly and still controllable.
  25. #25
    Apr 2011
    tx
    1,284
    Mad, I was checking those out the other day but didn't know they were the Castle. Pretty pricey but if they are the same as the castles they last for a long time. I've seen a couple new old stock of the 1515 pretty cheap but with the ribs they are a pain for cooling. May try the Dynamite on next build or when this one gives up. Hell, Im not positive its still good until I get it fired up anyway.
    Bp, that a bummer man. Ive lost a couple over the years but nothing of that great of importance. Get another one!
  26. #26
    Apr 2011
    tx
    1,284
    Do you guys know what size the hardware screws are in the v3 geico? Like the hold down tray and motor mounts. Not where I can look at my other one and want to pick some up. I believe they are 3mm x .5
  27. #27
    Feb 2011
    TN
    292
    Very nice! I still haven't cracked 70 in mine yet. What is your COG???
    Pursuit: T-180, TP 4060/1620kv. Genesis: T-180, GoolRC 2000kv. UL-1: Bone stock. MHZ Tsunami: Full tilt SAW project!
  28. #28
    Feb 2017
    na
    726
    Quote Originally Posted by Bp9145 View Post
    Brian, I hate to hear about you loosing yours. That's a tough one to swallow I know. I've got a hunch I can eek another mph or two out of mine...Hopefully, I'll do my best trying anyways.
    Quote Originally Posted by Turbo Dan-O View Post
    Thanks Dan! I normally like it at or near 30% for showing out with it...Lol! But 28% is a little more mph. Depending on the water conditions obviously though.
  29. #29
    Feb 2011
    TN
    292
    Man, that's crazy to me. So, your boat is around 30% with two batteries that far under the deck? Seems like it would be a snow plow!
    Here's mine at 30% or a little less...
  30. #30
    Jan 2013
    Ga
    1,358
    He said 28% you would need to move your lipos back probably touching your receiver or even a little farther. I want to say last time I ran mine I was at 29% and it ran really well. It all depends on your setup though really
