Results 1 to 10 of 10
Thread: 1" belt sander $35 coupon Harbor Frieght
    Aug 2012
    ma
    1,361
    Default 1" belt sander $35 coupon Harbor Frieght
    I already have this, and it is great, especially for rough work on props. It comes with an 80 grit belt, way too rough, I ordered 1"x30" belts on ebay.
    Like I said, I already own it so go ahead and print this coupon.....
    http://widgets.harborfreight.com/wsw...04&single=true
    ON
    9,398
    I'd like to find one of those for that price in Canada.
    Feb 2008
    Va
    4,670
    I use the 120 grit.
    IMPBA 20481S D-12
    Aug 2012
    ma
    1,361
    Quote Originally Posted by egneg View Post
    I use the 120 grit.
    I got a pack of 120's along with the sander at Harbor frieght, but I found if I'm not careful, it'lll take off more thane I wanted from the wrong areas(tips). I also thought about cutting the belts down to make them narrower and easier to get in on at various angles.
    ON
    9,398
    I find Octura's 642 & 645 to be very thin at the tips and it's very easy to take off too much. The X4 series is not as bad and Grim props are of course harder and work well with a belt sander.
    Aug 2012
    ma
    1,361
    Really?, the grim props seem softer, just much thicker, to me when I put a file to them.
    Feb 2008
    Va
    4,670
    I use the part of the belt above the steel plate so it forms to the shape of the blade better.
    IMPBA 20481S D-12
    Ga
    5,267
    Yep, or remove two screws and the plate comes off.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Aug 2012
    ma
    1,361
    Looking to hook up a vacuum to the port on the side, what are you guys doing to control the hazardous Beryllium dust?
    Feb 2008
    Va
    4,670
    Quote Originally Posted by kevinpratt823 View Post
    Same thing ... I have a shop vac hooked up.
    IMPBA 20481S D-12
