Page 8 of 11 FirstFirst ... 678910 ... LastLast
Results 211 to 240 of 312
Thread: *** NEW *** Pro Boat Veles 29 Catamaran
  1. #211
    Jun 2015
    Wi
    734
    Nice 4s run! I have a handful of smc packs they're great, have had them going on 2 years.
  2. #212
    Jun 2015
    Wi
    734
    Quote Originally Posted by MADRCER View Post
    I ran the boat today on 4s and got 57mph. More details on the "Veles fast list" thread if anyone is interested. Thanks to Chris for the custom ABC!
    Attachment 154279 Attachment 154280
    There's a member here jpriami that runs in the same location you do I think. Havent seen him on here in a while though, I know he got a 36 zelos when they first hit the shelves. Looks the same and he's from TN
  3. #213
    Jul 2016
    4,125
    Vinny does it again with another cool adjustment tool. FWIW, the strut and mount interface on the Veles is nearly identical to the 29 V3 cats. I use a scribe to etch lines in the strut where it sticks above the horizontal mount at my different settings.
  4. #214
    Feb 2017
    na
    726
    Quote Originally Posted by Mxkid261 View Post
    Thanks!
    Yes, This is one of the lakes that Justin has ran at in the past. I haven't seen or heard of him running at either of the two lakes since the "Geese" runs a year and a half or so ago at the other lake.
  5. #215
    Mar 2017
    ny
    283
    That's a cool idea. That would make it easy to make changes in the field.
  6. #216
    Jan 2015
    CA
    470
    Good run! That's the fastest I've seen on 4s. What size props is that?
    Rafael Lopez
    Product Developer-Pro Boat
  7. #217
    Feb 2017
    na
    726
    Quote Originally Posted by Rafael_Lopez View Post
    Thanks Rafael! That prop was a 1816. I tried to run it pretty hard almost through most of the run to check the temps and they seemed to be held in check. The ESC was 140° and motor 145° so I'm calling it good from my experience with the 3831.
  8. #218
    Jan 2015
    CA
    470
    Temps are on the border, but if you are not getting smell of epoxy from motor then you're doing OK. From what I have found, the solder will melt off the leads connecting the stater to the 12G wire before the motor burns.
    FYI, manufacturer says 150* is max for each.
    Rafael Lopez
  9. #219
    Feb 2017
    na
    726
    Good info Rafael Thanks! I'll push it a bit harder since now I know that I'm still under the manufacturers recommended max temps..LOL!
  10. #220
    Jan 2015
    CA
    470
    Max=
    Rafael Lopez
  11. #221
    May 2017
    OK
    1,464
    The Neo magnets start to de-guass at 160deg F, so you’re just making the motor weaker. This causes it to pull more current, which in turn makes it hotter... I would suggest keeping it below 135, because there is heat soak after the run when the water cooling stops. You can buy motors with high temp magnets, but they are pretty expensive. I think 200 degrees is the hottest that extended temp Neo mags can take...
  12. #222
    Feb 2017
    na
    726
    Great information! Thanks Craig. I'm not concerned at all about the ESC temps I have been getting, but if I start seeing above 145° in this particular motor on a clean run from start to finish then I start looking to make changes. I tested my 1815 prop and it is roughly 2mph slower than my 1816 on 4s in this boat with a little lower temps but still near 140° after the same type of run. From my experience over 30-35 runs that most all were in the neighborhood of 140°-145° range performance wise I haven't had the slightest issues at all with the 3831 motors and if I can continue to get fast speed results after multiple runs as I have been able to do even with the slightly higher temps than most are accustomed to seeing out of the traditional RTR motors I will be a very happy customer. Especially since you can sometimes find these motors in the $65.00 range to purchase. If they cost $165.00 each then I would be leaning a little bit more in the direction of propping down...Lol!
  13. #223
    May 2017
    OK
    1,464
    Those hi temp motors are $300-400! Neu has extended range. I have a question: are you taking these reported temps off a data logger during the run or after the run? If after, these are pretty typical. I have a shore cooler to keep it from heat soaking too high. I found that to be the trick, still allows me to use cheaper Leopard motors and not degrade them on hard runs. I’m not racing, but still the same, I run very hard.
  14. #224
    Feb 2017
    na
    726
    My Temps are taken right after the runs.
  15. #225
    May 2017
    OK
    1,464
    I think it’s about right... My data logger shows the motor temp sky rockets, as I’m idling in... Ive started taking a few cool down laps after really legging it, or should I say fingering it! So you’re seeing max temps, but not while the motor is running. The windings are usually hotter than the magnets, about 10 degrees typical.
  16. #226
    Jan 2015
    CA
    470
    For those that need an updated flex shaft, please call Product Support.
    Monday-Friday: 8 A.M. – 7 P.M. CST
    Saturday 8 A.M. – 5 P.M. CST
    Sunday: Closed
    Surface Vehicle Questions? Call 888-959-2306
    Rafael Lopez
  17. #227
    Feb 2017
    na
    726
    The Neu equipped Veles 29 gets a podium finish placing 3rd in the NAMBA Nats. Not too bad with virtually no setup time. Great Job Ken!
    P CATAMARAN:
    David Newland
    Jim Osborne
    Ken Haines
  18. #228
    Feb 2017
    na
    726
    Default A positive for the New Veles.
    On a positive note for the Veles at the Vegas Namba Nationals. Ken Haines was running a Veles equipped with a Neu motor and was having some issues with the handling/turning of the boat and due to the boat being brand new to Ken and all the classes he was running test time was limited. Ken and I chatted and I suggested a few things that would help him to get the boat dialed in better. Ken made those adjustments but he had already added a small skeg to try and help it turn better, but the skeg he added created a straighaway problem that Ken did not indentify until after the 2nd unsuccesful heat. Before heat 3 and 4 the small skeg was removed that was suggested from a fellow racer (like he was using on his Skater) and in the last 2 heats the boat was stellar and the word on the street was that it was the best boat in the field. But unfortunately for Ken those first 2 DNF's allowed him to only to recover to a 3rd place overall finish. Stlll all in all a very good showing for Pro Boats new release! Good job to Rafael on this one and again to Ken for another great finish!
  19. #229
    Jan 2015
    CA
    470
    Thanks for the update. This is very good news with very useful information.
    I think the take away here is that wheel time along with tuning for one's personal driving style is key, and it doesn't need add-ons like, like a skeg, to get the boat to perform well . Great job and big thanks to Ken for taking this box stock boat (other than motor) and throwing it on the water in such a big race. I have no doubt that if he'd have had more time to tune it and get used to the boat he's have taken first.
    Rafael Lopez
  20. #230
    Feb 2017
    na
    726
    No problem Rafael!
    On another note I received the replacement flex cable for the Veles today and Horizon was nice enough to send it totally complete with prop and all! The crimp looks much better than the original as well. Shouldn't be any issues with this one as long as you keep her under 75mph...
  21. #231
    Mar 2017
    ny
    283
    [QUOTE=MADRCER
    I got mine today also.
  22. #232
    Dec 2011
    ks
    69
    I got mine also today
  23. #233
    Feb 2017
    na
    726
    Default stock Veles Hits 77mph!!! (124kmh)
    Had to give this thread a bump! rcboone2000 this ones for you and Chris!! Merry Christmas!
    Veles 77mph 12-19-17.jpg Screenshot_2017-12-19-17-03-48.jpg Veles 29 77.05mph 12-19-17.JPG
  24. #234
    Dec 2010
    NY
    3,120
    Looking good Mark now you need some fresh batteries
  25. #235
    Dec 2011
    ks
    69
    Thanks mark.I'm waiting for 80mph post with Chris the propmaster helping just a matter of time
  26. #236
    Dec 2017
    NZ
    6
    First run with my new veles 29 15sec and lost the shaft at the crimp went down and got it at low tide
    Bad design didnt even get half throttle
    Awesome xmas present now on the shelf til end jan
  27. #237
    Oct 2013
    la
    8,740
    Quote Originally Posted by JAZA NZ View Post
    Why is it going to be on the shelf till the end of January?
  28. #238
    Dec 2017
    NZ
    6
    Waiting for a replacement from horizon usa shipping to new zealand xmas holiday etc.
  29. #239
    Mar 2017
    ny
    283
    My first flex broke exactly the same as yours. Personally, I wouldn't waist my time with their "Updated" flex. I have one, the crimp is supposed to be better, but it still looks the same as the original. just order this one from OSE. You wont be sorry.
    https://www.offshoreelectrics.com/pr...se-veles-cable
  30. #240
    Feb 2017
    na
    726
    Quote Originally Posted by dasboata View Post
    Thanks Chris...
    Quote Originally Posted by rcboone2000 View Post
    Thanks mark. I'm waiting for 80mph post with Chris the propmaster helping just a matter of time
    Maybe someday someone will....
    JAZA NZ Sorry to hear about your problems. I got an upgraded flex cable from Travis (kfxguy on here). He made up some Veles flex cables a few months ago that were some of the best quality ones that I've ever seen. Sometimes I can be a little rough on things but mine has handled everything that I've been able to throw at it with no issues at all. You should contact him to see if he has any more available from the batch he made up. I highly recommend it over the stock shaft. Even though my stock shaft never broke I was always weary of running it very hard. Contact dasboata on here and get you a 1716 prop and you'll never look back. Good luck with it.
