Mine are on their way. Had to wait for the owner of the company to get back to China from Chicago to clear up an attempt by his employee to overcharge me! All is well now. Should have them in a week or so.
WITH LED Program Box, shipped and insured:
120A $100
180A $115
They cost me $7 ea for shipping from China.
I have a waiting list if anyone wants to get on it. Already quite a few sold. I only have a small quantity coming in. They will go fast!
Mini Cat Racing USA
www.minicatracingusa.com
Hi Sailr,
Would you mind putting me on the list for 2 180A with programming box?
Anbjørn
I received an email that hobby city has the 120 turnigy's in stock.
IMPBA 20481S D-12
Mini Cat Racing USA
If all on the waiting list follow through, I only have 3 180A's and 4 120A's left!
Mini Cat Racing USA
Only TWO 180's and four 120's left if everyone on the waiting list follows through.
If you are not in the U.S. I will need for you to add $20 for international shipping. That is total, not each.
Mini Cat Racing USA
Mini Cat Racing USA
I just bougth a Seaking 180A (new versjon)
Is it waterproof or do i have to put some silicone somewere?
The esc is water proofed, but it may need epoxy around the plastic casing.
Sailr,
Are you down to 1 - 180A left?
I'm going to need 2 for a twin cat build.
One of the improvements to the 3sc's is two DC-DC regulator chips in the throttle channel cabe to protect the switching mode builtin BEC.
Mini Cat Racing USA
Pretty sure the BEC is good for the full cell count of the ESC rating.
Will it cause issues...depends on how well it is designed.
I just tested my so called new upgraded seaking 180A from Himodel today on 6s using the built inn BEC.
The BEC stopped working after 10 seconds
The guy from Himodel promissed me this was the new and better version but i cant see any DC-DC regulator chips?
How can i tell if this is the new version?
Check the pic a few posts back. It is in the rx wire. Also I would never use an esc's internal bec on 6s. get a rx pack or ubec
I'm never using an internal BEC again. Just fry, fry.
Not sure why Hobbywing had this idea up in their mind. To me this makes it look more fragile as the external DC-DC can be more easily damaged for it's more exposed to water, can be silicone sealed tho.
Perhaps I was having good luck? never had a problem with the internal BEC, 6S always.
Talked to Himodel today and they said:
Hi,
Firstly, we are sorry to hear that, but I would like to clarify one thing, that is we never do things like send old version as new version to customers.
We returned all the old ones to factory, and after nearly half a year, receive new supply from factory for those ESCs.
Reported to factory, they claim did not receive similar report from other customers so far, they take this very seriously as well, and want you to send it back for analyzing, also they want you to provide the following details:
Detail of motor: like KV, type etc.
Battery detail: voltage, discharge rate, capacity etc.
So as they can look into it further and see what might be the problem.
At this stage, I suggest to refund the cost of the ESC to you, you can re-order this ESC after some time till there are enough feedbacks from other customers to make sure the new ESCs are really reliable.
We can pay the returning cost of this ESC,
When returning, please:
a. use postal standard air mail for shipping, which is also the cheapest way.
b. declare a value no higher than $20USD, to avoid customs problem.
c. Put a piece of paper inside the packing, and mention this ticket ID.
Our postal address http://www.himodel.com/en/help/help.php?question=49
*!***!***!***!** Sincerely Yours,
The HiModel Team
Very good reply, surprised. Unfortunately Chinese ESCs keep letting people down
http://www.rcfastboats.com/
