Results 1 to 19 of 19
Thread: Counter Rotation Props Configuration
    Jul 2010
    CA
    409
    Default Counter Rotation Props Configuration
    I am putting together a FighterCat Cheetah and was wondering how to configure the rotation of the counter-rotating props? Should the LR prop be on the outside shaft or the inside shaft?
    We run a clockwise course at our pond if that makes a difference.
    Support US hobby suppliers
    Jul 2016
    4,121
    My twin Cheetah runs great with inward spinning props.
    Apr 2020
    CA
    702
    Same here with my ProMarine Skater X2...port side runs clockwise, and starboard side runs counterclockwise.
    ~ More peace, love, and kindness would make the world a much better place
    Dec 2010
    NY
    3,119
    most boats I see run the props turning to the inside they say inside for speed turning out side for handling !!1
    Apr 2020
    CA
    702
    Quote Originally Posted by dasboata View Post
    Chris, so you'd say 'inward' for racing, and 'outward' for SAW? Just curious, myself, as I'm also still learning.
    Jul 2010
    CA
    409
    I checked the "Big Boys" over at Mercury Racing and they run them turning inward; CW on the port side and CCW on the starboard side.
    Thanks!
    Dec 2010
    NY
    3,119
    Quote Originally Posted by Panther6834 View Post
    inside for SAW
    Apr 2020
    CA
    702
    inside for SAW
    Got ya ..so, inside for racing & SAW.
    Jul 2016
    4,121
    My experience has been it depends on both the hull and if you're after straight line stability or turning performance. What the full scale boats do doesn't really apply to us, the hydrodynamics are completely different... primarily because our props aren't scale sized.
    Oct 2020
    ZH
    50
    On a twin you just change the leads for changing the rotation direction right?
    Verzonden vanaf mijn iPhone met Tapatalk
    Jul 2016
    4,121
    Quote Originally Posted by ArnoudRC View Post
    No. To change the direction of a motor, you just swap any two wires, but then you MUST swap your flex cables and props to the opposite sides. If you don't swap your cables, you'll spin them in the wrong direction, causing them to unwind and potentially cause catastrophic damage.
    Oct 2020
    ZH
    50
    Tx. I?m aware of the rotation direction for the flexshafts. They differ. For the motor direction I was curious.
    Dec 2010
    NY
    3,119
    mis leading and damaging information on this conversation
    Oct 2020
    ZH
    50
    Was not the intention. Following the advice to run two props inward on a rc cat, I just wanted to be sure that (with the right flexshafts and props cw/ccw) I change motor direction by swapping the leads. Am preparing myself for a twin cat for next season, that?s why I ask. Is that damaging? Sorry.
    Jul 2010
    CA
    409
    Assuming that you have flex shafts that are wound in opposite directions, another way to reverse the motor direction is to program the ESC rotation (CW or CCW).
    I have my motor leads color-coded to keep the same wiring configuration in case I have to remove an ESC or motor.
  16. #16
    Oct 2020
    ZH
    50
    Thank you. Not sure if the stock Seakings 120 will accommodate that. Will check. Yes, I have ordered one piece flexshafts left and right for the boat (its a Zonda btw).
  17. #17
    Jul 2010
    CA
    409
    I checked my Seaking programming card and you are correct that you can NOT program the direction so you have to swap any two motor wires (and be sure to have the correct winding direction for each flex shaft).
  18. #18
    Oct 2020
    ZH
    50
    No worries. Got confirmed what I thought. Will redo the coloured shrink protection after tuning. Makes it easier to change motors.!
  19. #19
    Jul 2010
    CA
    409
    However, in my case I can't just swap motor leads. I need to also swap the two motor flex collet couplers because one coupler has LH threads and the other has RH threads. This is to keep each collet from coming loose from the counter-rotating motors.
