Originally Posted by
Prodrvr
No, you can run your motor on 6s.
Hasn't this been discussed enough already? Giving newbies (no offense to the op) advice to run high rpm is a recipe for disaster. For the experienced ok, but for some one who is on their second boat in 37 years, and first FE running the setup on 6s is asking for a burn up.
NOSBOD1 stick with the 4s advice, that setup will give you plenty of fun like that. You can prop up to a M447 for some extra speed, but always check your temps and time your runs. Keep your battery usage to no more than 80%. Even if you are going after speed, start slow and build up, testing and checking.
