I actually posted this already on my High Deep-V Thread but it's probably appropriate here too:
This is a quick and dirty of how I put together my brushless jet jam (scoots pretty good, FAR more fun than stock!)
Micro Proboat 3 wire servo $10 (from a different micro model, the jet jam has a 5 pin that only works with it's original esc)
Team Associated 14B RX/TX Set $0 (run Spektrum in all my cars, so it was a new takeoff)
Stock Blackjack 24" 30A 2-3s LiPo ESC $0 (EC3 connector stock)
Stock Battery w/EC3 Connector soldered on $3 (plan on buying a real battery for this, stock doesn't last long)
Brass junction cut and molded as a jet-drive water feed $3 (on port side jet-nozzle wall)
Surpass 2845 3800KV $22 on ebay in an OSE sourced $9 Leopard 28x40mm Water Jacket
(stock motor mounts!)
OSE Tubing and Bulkhead Fittings $14 (inlet)
Stock Blackjack 24" OEM water exit installed to Starboard "O" through Proboat graphics $0
Gutted Jet inlet Grate (smoothed and mild inlet ported with round files then sandpaper) $0
Thanks for reading! $61.00 spent!
