Page 80 of 81 FirstFirst ... 307078798081 LastLast
Results 2,371 to 2,400 of 2430
Thread: The official 36" zelos twin modding thread
  1. #2371
    Jun 2018
    la
    39
    also it has ran what seems to be hot .. i cant hold my finger on the cooling can hot.. i temped after getting home couple miles away . motors 142 esc 118 and bateries 146.. i cleaned cooling passages .. but the esc are new out the box from horizon . my stock ones had a issue that was warrantied . so do i need to set the timing in them? i bought the esc control box too .
  2. #2372
    Jun 2018
    MI
    3
    Hello, I just purchased a Zelos 36 put in 4 batteries they were each 3Sa batteries took one quick run turned around came back did not even hit half speed it caught wind blew through the air and cracked the hull in half.
    Proboat it was nice enough to replace it but indicated they don’t warrantee against crashes which I guess I understand so my question is I need to build some sort of an airfoil or air wing to put on the front to keep the nose down as I love the boat but I fear that I won’t make it thru the summer.
    Anyone have any tips or links to parts that I could bolt on to this boat to keep it grounded?
  3. #2373
    Jul 2016
    4,100
    Air dams have their place, but in stock trim, you don't really need one on the Zelos. What you do need is a good setup. Have you measured and adjusted the position of both struts and made sure they were tightened down securely as outlined in the manual? Other factors like unfavorable water conditions and wind speed can also contribute to easy blow overs.
  4. #2374
    Jul 2018
    FI
    17
    Here's one future owner of the Zelos 36, just placed an order.
    Im looking OSE's shops for spare/upgrade parts. What are the must do upgrades for this boat? I got some good advice in other thread to get breakaway screws for the rudder for spares, but what else now that im "shopping". Balanced and sharpened propellers are on my list too. Im gonna keep the electrics stock for now. Still haven't decided what lipo configuration im gonna choose, but 6s for sure. 2x3s or 4x3s or 2x6s lipos. I read that optimal balance is reached with 4 packs. Any suggestions or should I just go which feels right? My idea is to get 2 running sets so 8 packs feels quite pita if going for 4x3s packs.
  5. #2375
    Jun 2018
    la
    39
    Get the ose flex shaft savers so you don’t loose a shaft and prop if the collet loosened up , you can get some smc 7400mah 3s lipos and have more run time . The boat runs better I find on 4 batteries . Running on 2 3s only gets the adapters hot !! 6s packs don’t usually fit under the deck so you limited on boat stability I find . Also I say smc batts cause they have a 90c and up rating cause when you prop it up it’s gonna be more load on everything and you don’t wanna puff packs or have other issues .. also get a night tq waterproof metal gear Servo .. and while some say not needed I’d get the dual pick up rudder and cool the motors separate from the esc ..
  6. #2376
    Jul 2018
    FI
    17
    Thanks kyoshosp2! Didn't know there's such thing as flex cable saver. You seem to have good knowledge of the boat. How much there's room under the deck and the battery tray?
    SMC lipos seems to be out of the question as they don't ship internationally. Im thinking ordering all the lipos and charger from Hobbyking but there's no 90C rated ones in correct config..
    I didn't realize there's no pick up at the rudder. You are referring to this http://www.rcboatbitz.com/index.php?...3#prettyPhoto?
  7. #2377
    Jun 2018
    la
    39
    That’s the rudder ..try hrb lipos . 6000mah .. on eBay or amazon .. 6s is to thick to slide under front deck , Ive only seen one set do it and were a low mah rating which kinda negates using them to me ..
  8. #2378
    Jul 2018
    FI
    17
    Ok, ordered the rudder plus new better flex drive assemblys.
    I found Floureon lipos from Ebay while I was looking HRB's. Anybody has used them in boats? Got a bit mixed feeling about cheap lipos in general when looking different forums for experiences. The thing with them is that the C ratings could be anything and it's on the user to find it out. Are the hobbyking lipos legit?
  9. #2379
    Oct 2008
    CO
    9,488
    FYI all LiPO batteries, the labels are misleading, none of the C ratings are correct no matter how much you pay for the pack
    The hobbyking HD60C are a decent value
  10. #2380
    Jun 2018
    la
    39
    I ran some flyer on in a single .. I find the twins have higher amp draw so I’d stick with a wider used pack name ..
  11. #2381
    Jul 2018
    FI
    17
    Quote Originally Posted by Brushless55 View Post
    Ok, thanks! I ran my rc car with A123 Li-ion's, Lipos I don't have so much knowledge. Maybe I will discuss these more in the Battery thread..
    Quote Originally Posted by kyoshosp2 View Post
    Any idea how much one motor can draw amps in Zelos?
    Edit:.
    Well I made compromise. Got 2x6S HRB 6000mah and 4x3S Turnigy HD 5000mah packs. Thanks kyoshosp2 for the HRB lipo tip, Ebay has good prices for them. Now it will be painful couple weeks to get all the parts and the BOAT in my hands...
  12. #2382
    Jul 2018
    FI
    17
    Almost done! Still missing Dasboata's 1716 props... dang customs
    New servo, dual pick up rudder and changed the cooling lines for larger ID. Also re-route the ESC's, dunno if that's better or worse. Usually you shouldn't fix anything that isn't broken...oh well.
    About the gap between the drive dog and the strut. How it should be measured? Because the motors axle moves 1-2mm inside the motor and it affect the whole drive system.
    I noticed quite some vibrations at the hull when tested the throttle on a bench, is it normal? Of course short period of time, just to make sure everything was working.
    By the way is CRC's silicon grease good for the flex drive? It resist heat and water, and it doesn't brittle rubber/plastic.
  13. #2383
    Dec 2010
    NY
    3,116
    Quote Originally Posted by Hardstyle View Post
    do I have you on my list ?
  14. #2384
    Jul 2018
    FI
    17
    I don't believe I am, what list are you referring to? Sorry Im new in this forum.
    Thanks for hooking me up with the props im that Finnish guy. But now those are held in customs and of course im leaving vacation today.
  15. #2385
    Aug 2010
    uk
    2,887
    Boats run out of the water with no load on the prop will sound like a bag of spanners.
  16. #2386
    Jul 2018
    FI
    17
    Haha good to know, won't be doing that often then. Thing will fall apart before its maiden run.
  17. #2387
    Jul 2018
    FI
    17
    Got the boat running, dang it's fast even with stock props. But with Dasboatas custom props... all hell breaks loose, it's flipping, flying, wheeling, but mostly crashing. So my question is how can I make it to go faster? I did clock it at 64mph on calm water. I noticed that the strut adjustment is very important, almost over heated the electronics because the struts got too much negative angle. Didn't tighten enough the strut bolts and they fell down. For the 64mph run I had the props at stock 4mm positive angle. But it did bounce quite a lot. Batterys I had as far in the nose of the hull, got all 4 lipos side by side, 2 of the packs I had to put bottom of the sponsons.
    Is it normal that there's grease coming out where the struts are mounted to the hull (between the struts and the hull), or so it seems?
  18. #2388
    Jul 2016
    4,100
    Hardstyle, I assume you're running the ABC 1716 props? I believe that's what you were going to order. The ABC 17* series props produce less lift at the transom than the Octura style props, as such, I've found I need to run less positive trim on my struts when using the ABC's. I too like to run my batteries forward with two in the sponson bottoms. On average, my struts are closer to 2.5mm down from a straight edge run along the rear two ride pads. Now don't take that measurement, or anyone's, as gospel, because I've seen the struts mounted at varying heights in relation to the ride pad surface on multiple boats from the factory. Just a +/- 1mm difference in the strut mounting height will change your trim measurements relative to someone else's. When my struts come off the hull, I try to put them back exactly flush with the surface of the rear ride pad, and more importantly, dead even with each other. Make sure to tighten the adjusting bolt really well as strut adjustment can often get shifted during acrobatics. I drilled out my adjustment hole and used larger M4 hardware to get more torque applied and have not had problems with them moving since.
    Yes, a little grease leaking out between the strut and the hull is common. That same mating surface is where I've had multiple boats (others as well) leak water into the hull. The fix for both issues is to remove the struts, clean the mating surfaces thoroughly, and apply a little clear bathroom silicone caulk to seal it up. Use it sparingly as you don't want any to get into the strut at the teflon liner after you reinstall the strut.
  19. #2389
    Dec 2011
    ks
    69
    I put 1/2 oz resin and lead in the front of each sponson and I set it in water till it cured.There is a thread with this fix in it.
  20. #2390
    ON
    2,908
    1/2 oz resin and lead.
    How much Lead in each one??
    Larry
  21. #2391
    Dec 2011
    ks
    69
    1/2 oz total resin & lead mixed together in each sponsor.1 oz total.The sponsors split easy at the seam so the the resin and lead helps there
  22. #2392
    Jul 2018
    CA
    241
    Quote Originally Posted by rcboone2000 View Post
    did you use buckshot mixed in? or something else?
    i've used BB's in a sailboat for ballast.
  23. #2393
    Dec 2011
    ks
    69
    I used buckshot.be careful on the strut adjustments one-half of a mm a lot on this boat.If I remember correctly with dasboata 1716 it ran in the low 80s I love his props and the advice he gives along with madrcer on here.Also if you clean the bottom with lemon pledge it will run slicker.I don't run the Zelos much I like my veles better than all of my boats
  24. #2394
    Jul 2018
    CA
    241
    i need to do this to one of my builds, i have pounds of lead, just no buckshot. thanx for the advice. i like the idea of setting it in water, makes since, since it's how the boat will be well when in it's on the water ha! it's a brilliant idea.
    another foot note for the captains log.
  25. #2395
    Jul 2018
    FI
    17
    Yes you are correct 1716 props. Ok good to know, definitelly will do that M4 conversion for the struts, thanks.
    Yes it came to my mind to add extra weight to the front (or if that's what you meant even?), let see if I can't calm down the bouncing with the strut adjustments. That Pledge idea though, have to try that aswell!
    When looking the Zelos fast list, how is it possible to get it running over 80mph stock? Is the strut angles really the key? I got some new flex wires from Jeff Wolt, will try them out soon.
  26. #2396
    Dec 2011
    ks
    69
    You can calm down the boat with strut adjustments up around mid 60 mph the faster you go the more bow lift you have especially with the abc props.I have heard of people putting a straw in between the sponsons to disturb the air flow.I do that on my ul1 and ul19 hydro not the Zelos.1/2 mm is a lot of adjustment on the Zelos
  27. #2397
    Dec 2010
    NY
    3,116
    Quote Originally Posted by Stillwet View Post
    pretty sure what RCboone means is they put the sponsons tips in water because they believe the epoxy setting up will cause too much heat and distort the hull,, but mixed properly that will never happen \
  28. #2398
    Dec 2011
    ks
    69
    Thanks Chris that is what I should of said.I need to call you next week with a new project
  29. #2399
    Apr 2016
    Ca
    451
    Just touching base and saying hi. Still alive over here and the new build is still ongoing. Just been extremely busy with work, this winter looks to be slowing down. 👋
  30. #2400
    Sep 2018
    On
    8
