Zelos Fast List!!
  • REDLINE1
    • Jul 2016
    • 199
    #91
    Nice job!
    • Keagan-Z06
      • Mar 2016
      • 970
      #92
      Bested my time by .1mph with Poseidon motors on a choppy choppy lake 86.6 lol, at about 90% throttle. Got some props from Shawn as well that were used. Will confirm what those were.
      Edit: props are 1915's cut to 47mm
      • MADRCER
        • Feb 2017
        • 751
        #93
        I ran the boat again today for the first time with the 1814's Chris prepped for me. I have to give Chris (Dasboata) a BIG shout out for these props, they are the best ones yet...I believe I will have a little more speed next run when I get my new batteries in and a couple minor tweaks. This was my first test with this set up and I am liking it so far. Keagan can you update my credentials? Attached is a video and pictures that proves these numbers by 2 GPS devices. Thanks!
        76.3 mph zelos.jpg Zelos 77mph telementry 5-19-2017.jpg77mph Zelos twin 5-19-17.jpg
        Member: MADRCER
        MPH: 77.05 mph (124 km/h)
        Prop: ABC 1814-17-45 Dasboata
        ESC: Stock with timing 7.5
        Motor: Stock
        Batteries: 4x Gens Ace 5500 45C
        Mods: None
        • Keagan-Z06
          • Mar 2016
          • 970
          #94
          Updated for Madracer! Nice job man! You are top of the stock electronics list.
          • Erroneous
            • Apr 2016
            • 451
            #95
            Both of you. Have a feeling that this year $#+$ going to get real.
            • Keagan-Z06
              • Mar 2016
              • 970
              #96
              MadRCER, how long is that lake in feet? I use google maps to do a quick measurement to get an estimate. You are running 76-77 in what seems to be the same distance I ran my 86.6 in. I did 90 in my Zonda but it gets real iffy then.
              • MADRCER
                • Feb 2017
                • 751
                #97
                Keagan, The distance I ran in that video was around 850ft. The distance from the bank to the circle island in the middle of the lake is 1,000 ft. The overall straight line distance of the entire lake is 1600ft. If I start on the back and go straight out I run out of radio range somewhere around the circle island in the middle.
                • Keagan-Z06
                  • Mar 2016
                  • 970
                  #98
                  Ahhh, my lake has around 810 ft to run border line safely. I don't know how much more I can push the length of this lake and get away with it. Slowing down for a turn is already playing it close.
                  • Erroneous
                    • Apr 2016
                    • 451
                    #99
                    @Keagan... Nothin a lil dynamite and a backhoe cant fix!
                    • Keagan-Z06
                      • Mar 2016
                      • 970
                      #100
                      Man you have no idea!
                      • MADRCER
                        • Feb 2017
                        • 751
                        #101
                        Keagan I checked all my data logs and verified that I did officially log 124 km/h which translates to 77.05 mph. Would you update my status? 77.05 sounds better than 76.3... I updated my video with the info from the GPS devices as well. Below is my updated information and two photos as well. Thanks!
                        Member: MADRCER
                        MPH: 77.05 (124 km/h)
                        Motor: Stock
                        Mods: None
                        • Keagan-Z06
                          • Mar 2016
                          • 970
                          #102
                          Updated MADRCER! What equipment are you using to get your speeds displayed on google earth? I know datalogging, but what are you using?
                          • MADRCER
                            • Feb 2017
                            • 751
                            #103
                            Keagan,
                            I upload the files to the Gps logger software from Dynamite and then save and export the file as a .kml file to my Pc. Then you open the file with Google earth and it displays speeds and the breadcrumb trail where it was ran at along with the speeds at each checkpoint (it only displays speeds in km/h though). In my opinion it is the best testing tool one could use especially on a Rc boat because you can gauge easily how much distance you need to top out in rather than just wearing your stuff out running distances too long. Any other help needed let me know and I can talk you through it. I really like it because you can see every 10ft or so speed reading if you have it set to 10HZ refresh rate. I use it a lot testing and marking the distance my 3DR Solo traveled also.
                            • Keagan-Z06
                              • Mar 2016
                              • 970
                              #104
                              I have a Gamin forerunner and a dynamite GPS. Will try what you said shortly. Thanks!
                              • MADRCER
                                • Feb 2017
                                • 751
                                #105
                                Keagan this one's for you Bro! Sorry about the 3rd grade writing, I had to use my mouse pad on my laptop...LOL! Hope this helps.
