Results 1 to 3 of 3
Thread: JB weld on the flex
    Jun 2007
    LA
    764
    Default JB weld on the flex
    All I had to glue my flex into my stub shaft was some JB Weld. I would think it should hold fine. I just wanted to check. Anyone?
    IA
    811
    I do not see any problem with it. I glued my motor mount in with it. Make sure you let it cure for at least a day before using it. If you are worried that it may not hold you could also use the carbon fiber prop for the first 10 or so runs. This way if it falls off you won't be out a metal prop.
    Jun 2007
    LA
    764
    Thats what I am gonna do...it was pretty good on a x438, but the only carbon I have is a 35 and a 40MM. I'll try the 35 first.
