Page 1 of 2 12 LastLast
Results 1 to 30 of 33
Thread: 53.1 mph stock UL-1
    1,320
    Default 53.1 mph stock UL-1
    GOT SOME GPS PASSES IN, 53.1 MPH W/ 40/52-3- STRUT NEUTRAL , 5S LIPO CONFIGURATION 1 2S AND ONE 3S PACK ON TOP OF EACH OTHER PERPENDICULAR TO THE MOTOR ALL THE WAY BACK.
    1,320
    Saw style runs guys, i know i know
    Oct 2008
    9,488
    For some reason I cannot get my UL-1 to run 5s..
    It goes into some studder mode!
    3,117
    I hope you guys are not trying to run the stock UL-1 controller on 5S?!?!?!?!?!?!? I don't think that is what it was designed for...
    1,320
    Exactly what the title says- stock ul-1. Have been running 5s on 3 of my sv's for over a year now. As long as your careful and watch your temps, you'll be fine
    Dec 2008
    Vi
    409
    what about the cut off voltage on the UL-1 esc its set for 12 volts , that will kill your 5s set up if your not careful . i only bring this up for the newbes thinking they can run 5s with no problems ...
    Oct 2008
    9,488
    if one always runs your boat till the lvc kicks in, they could be taking their batteries down to far and hurting them..
    runs should always be timed..
    1,320
    I never run till cut off on 4s unless you want to puff the batts, and i would absolutely never run on 5s for more than a few laps.
    Oct 2008
    9,488
    Quote Originally Posted by 6S HYDRO View Post
    I agree bro!
    that's a sure way to kill lipos..
    1,320
    Quote Originally Posted by brushless55 View Post
    for some reason i cannot get my ul-1 to run 5s..
    there's no way for the esc to detect over voltage. And those esc's are rated to 20 volts. Something's probably wrong w/ your 3s connector
    Oct 2008
    9,488
    not sure?
    I even put on a BEC and still it studders..
    1,320
    Take off the bec- thats prob the problem. The stock ones handle it fine, like i said thery'r rated for 20 volts and ive been doin it on the 45a ones forever. Like i said before watch temps and short run times and you'll be fine
    Oct 2008
    9,488
    the BEC is not the problem just added insurance...
    it did this before I put it on..
    I'm thinking its my lame 12c batteries that's causing me issues..
    when I run 4s I have some nice 30c packs that get me 50mph
    Think I will put in an order for some good 3s packs this week, maybe zippies
    Oct 2008
    9,488
    Ok I tried my new 2s and 3s 30c packs and dang!
    I was running a S220 prop and this boat shot out of the water and was a handfull to get to top speed.. It kept lifting the left sponson up and out of the water.. Looked cool, nuts power!
    after about two minutes my UL-1 took off all by itself?
    come to find out my external BEC was only rated to 3s!
    and when I put 4s to it and took off the bec, some smoke came from my rx!
    Jun 2009
    423
    As far as Im concerned you are all liars unless we see some vids!!!
    Oct 2008
    9,488
    Ya, that's a good one!
    video of a smoking reciever
    May 2009
    3,180
    CC BEC up to 25V, 6S input with 4.8 - 9.0 volts selectable output using USB link
    DJI Drone Advanced Pilot
    Canada
    1,320
    i know my reciever started smoking today and i ran to get the camera, but by the time i got back it quit smoking so i didnt take any video
    Oct 2008
    9,488
    were you trying to get a video of a smoking reciever?
    1,320
    sarcasm
    Oct 2008
    9,488
    6,453
    How is an external bec rated at 3s? Why not just run a rx pack?
    1,320
    you guys dont need any bec. stock bec in the esc works perfectly- even at 5s
    Oct 2008
    9,488
    That's how is was made..
    I though I bought a 6s BEC, but the burnt rx said not!
    1,320
    if it burnt the rx that means the bec was putting out to much volts/amps to the receiver. like i said the esc's bec works great-no need for an external
    Oct 2008
    9,488
    Yes yes yes...
    I put on the BEC because of the issues that came with the first batch of escs I read about.. a little added insurance, so I thought
    but I'm going to give my UL-1 a try on 5s and the stock esc
    1,320
    just add caps to esc. every local radio shack has them for 1.39 ea. 35v 1000uf
    Oct 2008
    9,488
    I've read about these. Tell me again what this does for the esc
    and pics would help me out
    1,320
    i add 2
    1,320
    they are the weak link to the esc not the bec. you need to add on to the origional cap. i will try to get you piks of mine, but there are many on this forum
