Like I said Checkmate again! I'm finalizing my point with facts here. I spoke to the FCC today. So this is from them first hand! Jim Szelliga at 301 362-3000. Call and discuss if you want.
Q. Is there any law that states the following with the FCC Jim? "FCC laws very clearly state that within the United States that you cannot open up a transmitter and make any modifications, period."
A. No.
So not true! There is no such law.
Q. Is there anything illegal with how the Assan is being used installed of transmitting Jim?
A. "No, the Assan device fall under the 15C rules part.
Q. So what does that mean Jim?
A. There is no such law that states you can't open an already FCC approved radio and disable it and use the radio as host which is what the ASSAN is designed for as it's own stand alone transmitter. What is not FCC approved and illegal is to take an existing FCC radio and modify the EXISTING signal 75Mhz for example, or power output or the way it's broadcasting on that already FCC approved frequency which is 75Mhz."
So summary, there is no Law that says you can't open a FCC radio and disable it and use the rest of the radio as a host or shell and use the ASSAN that has been and is FCC approved as it's own stand alone transmitting device.
The ONLY issue is; the device is inside the radio and the rules say a device must show what the device is broadcasting at like a module would. So Assan just needs a sticker or something that shows the radio is operating as 2.4Ghz.
Q. Is this an issue Jim?
A. It's a minor issue but breaks no laws and that is the only real issue we see which is easily resolved.
I'm done. I hope all the people that are using the ASSAN are clear now that it's officially stated by the FCC you are not breaking any laws! Enjoy!
The ASSAN FCC links work for me: https://gullfoss2.fcc.gov/oetcf/tcb/...cc_id=VJ9XRF01
But here is a paste people that may have browser issues:
TCB GRANT OF EQUIPMENT
AUTHORIZATION TCB CertificationIssued Under the Authority of theFederal Communications CommissionBy:
Timco Engineering, Inc.
849 NW State Road 45
P.O. Box 370,
Newberry, FL 32669
Date of Grant: 11/05/2007
Application Dated: 11/05/2007 ASSAN ELECTRONIC CONTROL TECHNOLOGY CO., LTD.B1001, Xiya SquareNo.33 Yuzhou Rd.Chongqing, 40039
China Attention: Jianjun Meng , Vice General Manager
NOT TRANSFERABLE
EQUIPMENT AUTHORIZATION is hereby issued to the named GRANTEE, and is VALID ONLY for the equipment identified hereon for use under the Commission's Rules and Regulations listed below.
FCC IDENTIFIER: VJ9XRF01
Name of Grantee: ASSAN ELECTRONIC CONTROL TECHNOLOGY CO., LTD.
Equipment Class:Part 15 Low Power Communication Device TransmitterNotes:2.4GHz RF MODULE
Grant Notes FCC Rule Parts Frequency
Range (MHZ) Output
Watts Frequency
Tolerance Emission
Designator 15C2402.0 - 2480.0
