Results 1 to 28 of 28
Thread: castle on fire
    Jul 2009
    vc
    41
    Default castle on fire
    castle on fire
    Sep 2008
    OZ
    2,865
    wow thats nasty
    what was your setup when that happened
    Jul 2009
    vc
    41
    was running neu 1515 1.5y x646 on 6s2p need a new esc any ideas?? not castle
    Sep 2008
    OZ
    2,865
    what size esc was that
    Jul 2009
    vc
    41
    240
    Sep 2008
    OZ
    2,865
    i cant really help as i havent ran a nue or a cc hydra hopfully some of the guys with experiance on these will chime in as there was somthing serious wrong for it to go up like that,then again seems to be a lot off cc pop tarts going off
    Jul 2009
    vc
    41
    i think you get what you pay for and i think anything maid in germany is the way to go shulze and yeg i think it is the way to go
    Sep 2008
    OZ
    2,865
    a lot of guys are getting good runs with the ettis
    May 2007
    1,603
    Is it a HV or LV? If its a LV Castle and many others have warned against running it at its max voltage. For my 6s boats I only run HV controllers and they have been running great. If its a HV then that is a different story.
    Team Liquid Dash
    Jan 2009
    ct
    1,100
    My 240 just shorted out and went up in flames and started to cook the batteries at the same time.It was crazy to see smoke pouring out on a high speed run but not fun trying to rip the batts out and esc on fire . I had to submerge the boat under water while i pulled everything apart trying to save the hull.Talk about a nasty stench.LOL But...I beat on this esc for over a year real hard and pushed it to its limits 2 times a week straight.
    ma
    8,693
    What was the prop and boat size on that setup? Did you get many runs with that setup?
    Steven Vaccaro
    Jul 2009
    vc
    41
    its a lv on 6s2p neu 1515 1.5y x646 the hull is a h and m drifter 41 inches long i had about 20 runs speeds around 100 -110kph
    constant the only thing it can be is water got into the esc
    May 2007
    1,603
    If you have water getting into your hull that can def be the reason. The other problem is running a LV on 6s is just begging for disaster. I know people have had some luck running the LV on 6s...heck I even did it for a few runs but for the most part running a ESC at its max voltage OR amp rating will almost always end the same way...charcoal. That is also a large hull for a small 1515 size motor so I imagine it working pretty hard to push a 41" hull, probably pulling some big amps too.
    Team Liquid Dash
    on
    1,921
    try to NOT bunble your wires together with a zip tie~~
    EYEKANDYGRAPHICS
    www.rclipos.com
    Aug 2008
    3,071
    Waaaaaaaay to big a hull for that motor ........I am surprised u got that many runs in
    Jul 2008
    333
    Quote Originally Posted by 6ofthebest1 View Post
    You had it wired wrong too at battery side. You cannot run each wire to each battery with LV castle. You have to tie both wires together first. Did you flip the boat and get controller under water? That may kill it, but not in this destructive way. I think what got it is high power load with wrong wiring setup on battery side.
    Apr 2008
    LA
    1,510
    Antron is right. The wires need to be soldered together first. Neg+Neg,Pos+Pos
    Cool
    constant...
    I think others have covered most of the probable causes. Those long power wires are another cause, they are even worse when running close to the voltage limit of the ESC. Don't think that a wet controller can't turn to charcoal as the boards short out and the FETs start to go....
    I have run 240LVs since they came out and the only ones I've toasted were my fault - wet, SAW racing, etc. But then I consider the LV Castles as 4S controllers tops. With that small format motor in that hull the OP is asking for trouble from any controller, perhaps short of a 32-170. A 1527/1Y would be a far better choice for that hull unless the OP wants to keep buying ESCs.
    Jul 2009
    vc
    41
    that motor and prop wont be drawing more than 120 amps i have ran a hydra 120 and a barracuda 125 the same way there was a bit of water inside when i got it back it has to be the water that got into the esc
    when yous say the hull is to big for the motor with a 1521 1y it ran a high of 111kph
    with a 1515 1.5y 109 kph with more runtime
    so what motor should i use i think that 1515 motor is for that size hull
    Jun 2007
    5,190
    How are you measuring your amp draw and speed? As many have stated 6S voltage on that esc is not a good idea. As for the motor you have had a very good suggestion.
    Douggie
    Nov 2007
    6,927
    You need a bank loan to buy the Schulze's. I've seen two of them smoke in one day also.
    Mini Cat Racing USA
    www.minicatracingusa.com
    Jul 2008
    333
    That setup was drawing way more than 120A. I had same motor with 6S and 42mm prop in 30" hydro and I was doing 80 - 100A continuous at full speed.
    46mm prop will put you in 200 - 300A territory, my guess.
    Dec 2007
    me
    406
    I have seen this boat run and it is quick, it was setup By AndrewG @ fastelectrics, and have seen the data logger results it runs around 120-135 amps. He also ran a 125amp speedy 20+ times until a wire cam off it and it blew, so the setup is ok to me, but i am no expert
    returning to boats after a big break
    May 2007
    1,603
    Well I am very impressed to see that a 1515 motor can push a boat that large.
    Team Liquid Dash
    Aug 2008
    3,071
    Quote Originally Posted by Raydee View Post
    hey you can get it to move using rubber bands but for how long...i still say 1515 is to small to move it at any decent speed for any lenght of time
    Jul 2008
    333
    Quote Originally Posted by Apples1 View Post
    I wonder how he wired data logger to that controller. Since on the picture it looks like battery wires are not tied together (+ to +, - to -), if he only measured one side of Hydra 240, and got a result you posted, then that controller is maxed out (135A * 2 = 270A). When the wire comes off the board, it means it got so hot, that solder has melted. That happens when controller shorts out first, then wires get hot enough to melt solder, from passing 400 - 600A of short circuit current. This what kept my LiPos from getting fried from my past 3 (or 4) blow ups.
    Dec 2007
    me
    406
    not sure how it was wired up for the data logger Andrew did it, on the old ESC, not this one.
    Jul 2009
    vc
    41
    it was logged using a 120 hydro esc i have some clips of this boat on you tube under 6ofthebest1 using a 1521 the 1515 is a few kays slower i have ran 1521 with a 120 hydra and that was ok to so to say the 1515 1.5y is doing 200-300 amps while using a 120 esc sound just about rigth the h and m hulls a very ligth fully loaded with 2 6s packs under 4kg
