Results 1 to 11 of 11
Thread: esc cooler-no solderig
    Default esc cooler-no solderig
    first! im so sorry for me goofy english!!
    so...
    Im building some boats and im tired to spend money
    i have a jes030 for plane left,and i dont want to buy a 80 bucks navy esc...
    this convertion idea come from Steven from OffShore Electrics..i just did in diferent way..thank you Steven!
    so i decide to build one..but i am a horrible welder!! then i did this method..
    and you know what? works !!! and very well!!!
    and the best part..no soldering!!
    for this build i use this parts:
    thin aluminum foil..
    aluminum tube..
    some closed cell rubber..
    epoxi resin...
    k&s brass half square..
    in first place,lets waterproof the eletronics...
    remove the heat sink..
    brush some layers of epoxi resin..
    now,follow the pics...
    Default second part
    i use some k&s half square tube just for security
    cheers!!
    Nov 2007
    6,927
    Good job!
    Mini Cat Racing USA
    www.minicatracingusa.com
    Jan 2008
    Mo
    2,716
    Yep nice work but are you sure it won't leak? That would be my concern.
    yep!!
    i did a pressure test with an air compressor and no problem! btw,a lot pressure!
    i would say that..almost blows in my face! ...but didnt leak..
    cheers!!
    Mar 2009
    AZ
    1,320
    That looks very risky
    dont worry..works!
    btw.. very well!
    I did several tests and the ESC is not warm either. complete cool!!
    Jul 2008
    WA
    772
    Quote Originally Posted by Jeff Wohlt View Post
    I have built one with house door type rubber gasket. simple and easy. I used the esc finned cooling plate I had removed as the outside plate
    an RC rock crawler lost in a sea of boat parts.........
    ma
    8,694
    Nice job. Nice seeing other ways to come to the same result!
    Steven Vaccaro
