Page 1 of 15 12311 ... LastLast
Results 1 to 30 of 430
Thread: Littlescreamers 63mmwater jacketed Motor
    Jan 2009
    Wa
    60
    Default Littlescreamers 63mmwater jacketed Motor
    Steven had asked me to post a little something about our new water jacketed outrunners we are producing. This is a project I have been working on for some time now and am very excited to be able to show off what we have coming out soon. I am posting some pictures as it is way simpler to show you how it work then to explain it.
    I will give it a shot!
    The internal cooling works by passing cold water through a bell attached at the end of the motor, This bell is removable and is sealed with 2 O-rings one front and one rear. this bell is completely enclosed and sealed, No water can enter the motor or the shaft as the bearing on the end is outside the bell and sealed with the O-ring. (see pic) Inside this bell is an extension of the bearing tube witch also holds the stator, Now on this extension I have machined cooling fins to absorb the heat with the water passing over these colling fins and the whole things is Aluminum so it wil act like a heat sink. So with this setup there will be no issues with heat and as all of it will be pulled strait from the motor and out the exit! The faster you go the better the cooling.
    As of now we are going to release 3 versions of this design
    1 for the Mini boats
    1 for the mid size boats
    And a competition 1/8th 1/10th scale motor
    Here is a picture of the new production 63mm water jacketed motor for 1/8th and 1/10th
    ca
    6,963
    Very interesting. What are the KV's ?
    Jan 2009
    Wa
    60
    Thats a good question. I am not sure what the finial KV will be we just had these done at around 650kv and I will adjust it as needed, i will have one being tested this weekend and then can give a little more on the targeted KV
    Scott
    May 2007
    1,603
    That is NICE! I just read a post where they are having great success with the outrunner's in the large hulls. Water cooling them is even better, might possibly make inrunners a thing of the past in a few years.
    Team Liquid Dash
    Wa
    5,905
    The ones being used up here in the Seattle Area in the bigger boatsd I don't think they are even watercooling them. They don't seem to get hot at all
    Billy Graham
    Jan 2009
    Wa
    60
    then there not running them hard enough!
    Scott
    Wa
    5,905
    There are a lot of people especially in Seattle that don't run to break speed records and run spec setups
    Billy Graham
    ma
    8,694
    Scott any updates on these?
    Steven Vaccaro
    Nov 2007
    6,927
    Scott, you said you were gonna send me one of these?
    Mini Cat Racing USA
    www.minicatracingusa.com
    Jan 2009
    Wa
    60
    Ok
    I have a little more info on the motor.
    This Large Water Jacketed Outrunner was designed for big boats 40-90". It will perform well as a drop in HP replacement for the Weed Eater type gas boats. Designed as a racing motor to run against the gas and will be competing in the racing scene beginning 2010. Testing so far in a 40+ Race hydro we are running 65-68 MPH and completing 7+ laps on 10s. This is very exciting for a low cost alternative motor to be running with the $600 Modified gas motors and the Large Neu inrunners. Testing continues and I will update soon!
    These pictures are from the 55" Deep Vee I am doing a conversion on. I started with a new hull (Snagged from the LHS for $50 new in the box) and then bought all new Proboat hardware, I am waiting on an ESC and then I will finish this project. I am very excited to see this thing scream across the lake with the new power system.
    Order one from Littlescreamers.com Today
    KV650
    Shaft 8mm
    Watts?? 8,000
    Scott
    Jan 2009
    Wa
    60
    Here is a couple pictures of the XPS sponsored race boat. this is the boat all the testing has been done with.
    7,279
    Price????
    Jan 2009
    Wa
    60
    OH Sorry,
    MSRP $179.99 But we are running a sale of a small quantity to promote this new motor and you can order one today for $149.99 + Shipping.
    Scott
    ca
    6,963
    Scott, any release info on a 4S, 1800 - 2200 KV motor ? I'm sure there's a big audience for something to compete with the Neu 1515 / 1521 types.
    Jan 2009
    Wa
    60
    Working on that one now, I have 5 new motor designs going to the factory. 2 are smaller versions of this motor.
    I will keep you all updated on how things are coming along.
    Scott
    Aug 2007
    3,031
    I am interested in the 1/8 scale motor, how can I get a motor with a little more Kv, something in the neighborhood of 800Kv to 950Kv...
    Also, what are the dimensions of the motor? What size of the bolt pattern? What is the water cooling nipple size? Warranty?
    One more thing, about the 8000w, is that constant draw or spikes? 'Cause having a motor pulling 216 amps constantly is pretty grueling...
    even more so if on 8s.
    This is looking good Scott.
    Jan 2009
    Wa
    60
    Quote Originally Posted by Ub Hauled View Post
    I am interested in the 1/8 scale motor, how can I get a motor with a little more Kv, something in the neighborhood of 800Kv to 950Kv...That will have to wait until our next order.
    Also, what are the dimensions of the motor? It is 63mmx117mm with a 8mm shaftWhat size of the bolt pattern? 40mm 6mm bolts What is the water cooling nipple size? It is drilled for a 1/8th brass tube but I will be installing large nipples at the factory in the next batch. Warranty? All our motors have a 2 year Warranty
    One more thing, about the 8000w, is that constant draw or spikes? 'Cause having a motor pulling 216 amps constantly is pretty grueling... That is a rated number. Not what your going to be getting.
    Scott
    Aug 2007
    3,031
    Quote Originally Posted by Littlescreamers View Post
    Scott
    Thanks for the answers Scott, I'll be following this thread closely...
    Aug 2008
    Ia
    22
    Ok
    This is very exciting for a low cost alternative motor to be running with the $600 Modified gas motors. Testing continues and I will update soon!
    Scott
    Low cost compared to a $600 gas engine?
    How much will the esc and a few sets of batteries and a charger cost?
    It would take at least 3 sets of battries, maybe 4 to keep you on the water like a gas engine.
    ma
    8,694
    Quote Originally Posted by REBAR View Post
    Only on lakes and ponds where gas boats are allowed.
    Steven Vaccaro
    7,279
    I just ordered one. Going to try it in my 42" Cat on 10S
    Nov 2007
    6,927
    Let us know how it works out and what kind of prop you can swing on 10S. Need to be a bigun' with such a low KV.
    Mini Cat Racing USA
    May 2008
    961
    ma
    8,694
    I now have these in stock.
    http://www.offshoreelectrics.com/pro...ls-63outrunner
    Its one hell of a beast. Its a ton of motor for the money. Literally!
    Steven Vaccaro
    Aug 2007
    3,031
    Sweet Steven... I hope to get a higher Kv version... what is the story on those?
    ma
    8,694
    There has been a bunch of success wih this motor and kv, so as far as I know this is the kv for now.
    Scott, designed the motor as a performance replacement for customers that what to replace modified zenoah motors. On 10s it will have more rpm and on 12s it will have much more rpm.
    There was some talk of Zenoah motors and kv in this thread.
    https://forums.offshoreelectrics.com/...ighlight=motor
    Steven Vaccaro
    7,279
    Mine still hasn't got here yet.
    May 2007
    LS
    127
    @steven
    I´m very interested in that motor but to be competitiv it would be nessesary to get min 800rpm under load. i´m just converting a X-Ray from Hydro&Marine (1,38m) with a Scorpion 4035 with 800rpm(waiting for the Motor).
    The Littlescreemer would be a good alternativ.
    Greetings
    Axel
    Nov 2007
    6,927
    I believe Scott is considering higher KV versions in the future. In the meantime, the 650KV will swing a huge prop! On 10S, the no load RPM is 24,050!
    Mini Cat Racing USA
    ma
    8,694
    Quote Originally Posted by axel View Post
    @steven
    Greetings
    Axel
    That was discussed here
    The consensus was that this will have more rpm than a modified Zenoah, which should keep it right up with the pack. I haven't had the chance to test one. I hope to get a hull for the summer.
    Steven Vaccaro
