dose anybody know how to rewire ESC to go in reverse?
swap motor leads ... but why?
IMPBA 20481S D-12
because my esc say that it has reverse and i would like to find out how to use it. i would like my boat to go in reverse when i need it to....
If you wire the esc in reverse then it will be in reverse all the time.
Im pretty sure in order to turn on reverse if it even has reverse, you need to go into the programming mode for the esc.
Use your manual.
A programming card will help also.
Where in Illinois are you from?
Z
KBB34" Mono - Fast
ToySport Triton- Not as fast
mulberry grove by vandalia. so i have to reprogram the esc, the programming card that i have does not have that on it is ther another way? the esc say that it has reverse, but i can not find any info. on how to trun it on
Where are you finding this info that this esc has reverse?
Z
KBB34" Mono - Fast
hears the link i had to copy and paste. and that is what it say http://www.offshoreelectrics.com/pro...rod=dh-prb2314
That is not the esc in your boat..
That is for brushed motors.
This is the esc you have.
http://www.horizonhobby.com/Products...ProdID=PRB3309
Z
KBB34" Mono - Fast
ok you are right i guess that i was looking at the wrong one i guess that my boat does not have it. thank you for the help
If you NEED reverse then you need a slower boat.
No easier way to say it.
Z
KBB34" Mono - Fast
Formula Fastech has no reverse. Shockwave has it.
DJI Drone Pilot
Canada
