looks like youve got the negative and positive's swapped on your adapter?
Z
KBB34" Mono - Fast
ToySport Triton- Not as fast
you are a sick puppy my friend but i luv the idea send the site
ok tks will tonight
Very short video, my cam is garbage!lol
LMT
LehnerMotorenTechnik.com
Man i am too excited.
I cannot wait for my 12l to show up.
Im going to try out a x642 with my seaking 180a esc.
Z
KBB34" Mono - Fast
Looks like ytour boat doesnt hop in the right turns, was it like that only after your turn fin upgrade?
12L is in my boat now and so is a Seaking 180a speed control.
I need to get rid of my left over radio box and put in a piece of wood so i can move my servo further back. Not enough room right now for my liking for the seaking.
Z
KBB34" Mono - Fast
kintec racing make a direct fit with servo mount
Yup, seen it.
But i can get the same wood at my Hobby Lobby for $3 for a 12x8" piece.
Ive got the resin to seal it with. Just need to get a servo mount ordered and i'll be good to go.
Z
KBB34" Mono - Fast
Z400,
Do you have a video and pic's of yours?
LMT
I went on eBay on bought an eTrexH GPS, Ill be getting exact speeds next weekend on this setup.
LMT
Stock electronics
http://www.youtube.com/watch?v=LQRGs4150jQ
Z
KBB34" Mono - Fast
move the cog a little more foreward will stop alot of the bouncing, move trim tabs down a little will help too (:
nate how much did you get the etrex for
boat looks great z
you could raise the strut a little move it up some, it will be faster good luck, papa
ive already lowered the trim tabs a bit since last run. i knew about the COG problem last time i was out i just didnt have velcro in the right spots in order to move my batteries up. Problem fixed now though. Next run will be with my 12l and 180a esc hopefully. Think i could run a p220 prop with the 12l and the stock esc?
Z
KBB34" Mono - Fast
possibly, try a couple of runs and check temp's
same thing but mine is blue !!!!!!!!
hell yes just put it on max speed and off u go hold max speed achieved
gives you distance travled and elapsed time great great gadjet
Sweet, I need one bad Iv been thinking about what the exact speeds are on my white SV.
Here's the motor and esc I have laying around for your UL-1...
The motor is new and came straight out of the G-force a-z hydro, and has been ran 1 time.
This motor ran well on 4s and an x440.
The esc has been ran about 15 times on 4s, and works OK... The problem is, I can't ever seem to get it to program right the first time i plug in the batts,
I always have to pull the power to the reciever then plug it back in, then it seems to beep once like it was suppose to... anyways It does work but thats the only issue.
Id take $70.00 shipped for the motor and esc only
LMT
opps hold on... haha
LMT
LMT
the cooling jacket is made on to the motor do you have missing fitting
