Page 2 of 2 FirstFirst 12
Results 31 to 34 of 34
Thread: 2.4 gig transmitter/receiver
  1. #31
    Apr 2009
    la
    2,330
    i here you good luck with the radio problems 75mhz fm maybe a answer the synthsized fm system
    may be a cure 4 u
  2. #32
    Wa
    5,905
    I seem to remember reading something about keeping the TX antenna vertical. What about BEC are you using BEC or are you running off a receiver battery and if you are using a receiver battery what is the voltage
    Billy Graham
  3. #33
    May 2007
    no
    415
    i m currently using the BEC... also tried a rx battery (4 X AA = 6 v)... still the same result... glitch ville...
    guess i ll try to hold the tx more vertical when i run her this arvo..
    cheers
  4. #34
    Apr 2009
    BJ
    251
    I use 3PKS 2.4G in my boat for a year without a single problem. There are rumors around saying 2.4G no good for marine, by far I didn't experience that.
    One thing I love 2.4G here is that my boat has no visible antenna, it's hidden inside the hull, results in less wind drag, less holes to worry about for water sealing, ease to carry around, and imo far better look.
