Results 1 to 13 of 13
Thread: servo torque
    Jan 2009
    ca
    842
    Default servo torque
    I need a new steering servo but was wondering what torque would be appropriate for a boat. I've seen them from16 oz/in to 65 oz/in. Any help would be appreciated, Thanks
    Mar 2007
    VA
    7,212
    How big is the boat and how fast do you expect it to run? Lipos or NImh?
    Jan 2009
    ca
    842
    32 inches with a OSE 700 sc on NiMH 2 8.4 in series top speed 30 MPH. It's the yellow one in my avatar. Good question as speed seems like the determinating (sp) factor.
    Mar 2007
    VA
    7,212
    The HS-311 should be more than adequate!
    Control System: +Pulse Width Control 1500usec Neutral
    Required Pulse: 3-5 Volt Peak to Peak Square Wave
    Operating Voltage: 4.8-6.0 Volts
    Operating Temperature Range: -20 to +60 Degree C
    Operating Speed (4.8V): 0.19sec/60° at no load
    Operating Speed (6.0V): 0.15sec/60° at no load
    Stall Torque (4.8V): 42 oz/in (3.0 kg/cm)
    Stall Torque (6.0V): 49 oz/in (4.5 kg/cm)
    Current Drain (4.8V): 7.4mA/idle, 160mA no load operating
    Current Drain (6.0V): 7.7mA/idle, 180mA no load operating
    Dead Band Width: 5usec
    Operating Angle: 45° one side pulse traveling 450usec
    Direction: Multi-directional
    Motor Type: Cored Metal Brush
    Potentiometer Drive: 4 Slider/Direct Drive
    Bearing Type: Top Resin Bushing
    Gear Type: Nylon
    360 Modifiable: Yes
    Connector Wire Length: 11.81" (300mm)
    Weight: 1.52oz (43g)
    Jan 2009
    ca
    842
    WOW, that is a lot of info but what controls the voltage going to the servo and do I have any control over that? Doesn't the receiver take care of the voltage going to the servo? I take it that servos are a stall motor but don't understand how it could go from zero to full steer in steps, a rheostat maybe and what brings it back to zero, a spring?
    Mar 2007
    VA
    7,212
    Yes the voltage is controlled by the ESC which provides power to the servo from the main battery. (unless it's an Opto ESC)
    The servo is controlled by a series of pulses through the signal wire, where the length of the pulse indicates the position to take.
    Jan 2009
    ca
    842
    The receiver or the ESC controls the servo? okay, I'm liking the pulse thing as how the servo works and this gives me something else to ponder as I have a 1952 hard drive. Thanks
    Jan 2009
    ca
    842
    I'm going to make the assumption that the speed requires more torque to turn so I think a good rule of thumb would be speed plus 50% for size of servo. I.E. 30 mph plus 15 =45 in/oz and for you fast dudes that do 70, I would say 70+35= 105 in/oz servo. Just a guess but can anyone come up with a formula or an idea on how to rate servos or am I way off base here?
    Mar 2007
    VA
    7,212
    So many numbers... too much math, my head hurts!
    The speed does play a part, but to what degree to derive a formula, I don't know. My renegade's servo was fine for the speeds I was getting, then I put on a custom made V932/3 prop, and now the servo doesn't have the torque to turn her anymore (full throttle). I'd like to know the formula, but it would have to factor in the weight of the boat, depth of the rudder, width of the rudder, speed, hull type, etc...
    Jan 2009
    ca
    842
    I think speed is the key ingredient here as it will be harder to turn the rudder the faster you go. I would eliminate rudder size, hull shape and weight of boat in this formula and stick to the key factors. I love math and this is getting a little too heavy for me. OKAY I'll go with hull size as an issue and weight of boat too! You're right! What about my formula?
    May 2008
    OH
    774
    For any boat speed over 40 mph, I only use 100 oz + servos, you only have to loose 1 boat to prove this theory in!
    It's worked for 14 years, so far. LOL
    Cool
    Don't try to "over-engineer" this as there are too many important variables you have chosen to ignore. Rudder size is almost as important as speed, but the centrifugal force of the boat in a turn is just as vital. Too, where in relation to the front edge of the rudder is the pivot axis? How long is the steering arm on the rudder? You simply cannot ignore all the variables - that would be like assuming that a certain speed requires the same voltage regardless of the boat....
    Go by experience, not some unproven, flawed math theory.
    Mar 2007
    VA
    7,212
    Quote Originally Posted by jcald2000 View Post
    You must only run big heavy boats then, because that's overkill to a boat like the Renegade.
