Results 1 to 7 of 7
Thread: 2.4 GHz 'DSM' antenna length.
    Au
    446
    Default 2.4 GHz 'DSM' antenna length.
    I am about to switch to Futaba FASST for all my boats but am a bit worried about the occasional report of radio problems due to the receiver antenna being masked by carbon fibre hulls or water spray from rooster tails etc.
    I am aware that the antenna wire is shielded for most of its length so that in fact only the unshielded bit on the end is actually the antenna.
    This exposed portion must be a tuned length, so my question is can this be extended in multiples of this tuned length to provide an antenna that is well clear of the hull and spray ?
    Or alternatively can the shielded portion be extended to give a longer total length but still with the original exposed wire on the end ?
    Has any experimenting or research been done on this issue ?
    Graham.
    Jan 2008
    IN
    796
    I would think mounting a antenna tube and capping it would be fine. the antenna on the fasst are "stiffer" than the old style so if you mount it under the antenna tube lets say, it would stand pretty much on its own. Orif you mount the rx next to the tube upside down just put some hatch tape across to keep it from falling out. Also yes, I have heard of problems with carbon hulls, but to honest I have heard of problems with abs hulls as well. Personally I have had no problems and I dont even run the antenna out of the hulls.
    Jul 2008
    333
    Quote Originally Posted by G Doggett View Post
    No, unshielded part cannot be extended in multiples. Making shielded part longer is fine, but would not be easy with this receiver. Just mount your receiver in a way so you can run this antenna through a hole and have the wire in a tube sticking out outside of your boat.
    If you absolutely want to extend that antenna, you can cut off unshielded part and crimp the cable to reverse SMA connector, then buy small mobile WiFi antenna and glue it to outside of your boat anywhere on metallic or conductive surface to form good ground for that antenna.
    AK
    391
    Graham.
    Hi Graham as you know i have done all the wrong things with my Fasst radio never had the antenna out of the radio box always taped inside,in the lizard it's sitting next to my motor surrounded by carbon fiber,in the chaparral it's about 75 mm from the bottom of the v, never had a glitch in over two years of use i don't think anyone running Fasst at the club ever had any problems with it
    Just go buy one don't play or change anything, and enjoy
    Adrian
    Nov 2008
    SA
    708
    I also run my Futaba 3PM 2,4GHz Rx laying down inside my fibreglass hull and my range and response is fantastic. No glitches and no issues. Only thing with Futaba is you need to reverse the throttle channel, but that is easy to do.
    Au
    446
    I've just ordered a 3PM 2.4GHz set from Tower Hobbies tonight.
    I'm tired of waiting for the Kiwi dollar to improve.
    Should see it in about 2 weeks.
    Graham.
    Cool
    You will not be sorry. I've been racing a FASST for months and even in a high-powered carbon fiber hull it works great as far as I care to run, plus a bit.
