Ok, now an application question. I just brought my DF33 mono in from a 2-3 min test run and the Etti 150 was 160F and shutting down. The set up was my LOW DRAW test run:
Neu 1521/1.5D, 4S2P 4800 mah (9600 total) and a..... X442 prop!?!? I did maybe 6 laps in our maybe 70 yard pond, she was probably 35+ mph. But I don't get why it was getting hot so fast? The motor was not even 80F....
Yes water cooling, yes it is the BEC version, yes cable was well lubed and spinning freely, yes the motor was aligned perfectly with the stuffing tube, no I didn't have an external rx battery (I have done that before) .....
Is it a function of running 4S in parallel? What am I missing? Could the darn thing be programmed wrong? I found it far from plug and play.
Is there a way to reset it and start over?
