Originally Posted by
Shooter
Is it a problem when the strut bushing slides axially? Mine not only rotates, but slides back and forth within the gap that I allow between the drive dog and strut end? It usually ends up at the drive dog end because of the pitch of the flex cable windings. Does anyone else experience this? Is this a problem? Thanks.
Shooter, I'm experiencing the same situation on one of my boats that was set up by the person I bought it from. My thinking is that it shouldn't be a problem; if any forward force exerted on the bushing is created by flex windup it will just push the bushing back forward given that the bushing is free enough to slide in either direction. I do lube after every day's run, BTW.
OTOH, I just set up a hydro with one of Jeff's .078 wire drives which includes his ball-bearing strut and believe this is a great way to reduce parasitic driveline drag.
I grease & lube after each day's run as well and am just thrilled with this setup.
