How does the paint hold up on these boats? If you do paint what to be aware of....
Anyone do custom painting?
I painted mine over the winter and sprayed Testors enamel. It looked pretty good once it was all done (I sanded, primed, painted and clear coated) but it hasn't been very durable. I wouldn't recommend using that paint.
If/when I repaint, I think I will use something more of automotive quality.
Grand River Marine Modellers, el Presidente
IROC VUP, 25" Prince Mono, Mini Hydro, Classic Barrel Back, brushless Mini Rio and two Nitro Tunnels
Here's some sweet Toxic green I done that was used just from a can..
Then cleared..all in all it will usually cost me $85.00-100.00 a hull for paint but always does pretty nice.
LMT
LehnerMotorenTechnik.com
Nice paint.....I'd like a metallic sparkle blue color. Did u sand and prime it? Kinds paint?
2 Coats of Valspar Grey primer, light sand soft grit, then the base green which is by Killer cans Alsa inc. then 2 coats of clear...then wax and boom done!
LMT
Can I just tape off the boat and take decals off and spray a couple coats over existing paint..Will it hold with decent paint?
After I pull the stickers off just spray primer first? I don't have to sand the boat first only sand after I spray the primer? Do I have to remove the blue paint off the top of the boat or can I just spray primer over it?
Dude you need to do a light sand over the first layer of paint...then get you coat of primer on next.
After about two coats of primer I usually take a scruff pad ect and soften the primer up.
Then do your base coat...
then re-sand again....
Then get a body shop to put 2 coats of clear if you dont have the Air and guns to spray clear..
LMT
Can't you just spray clear coat in can?
There is someone from rc universe who is going to paint it....I don't have the room to do it.
Hmm put up a boat that you painted that looks as good.... "Douggie" lol
LMT
Soften as in sand it to a smooth surface... as primer is sprayed on, it can be rough when its fully dried... whats bad technique is your smarta$$ on forums...no help at all man.
LMT
A response you Twit
Now let us see your TRUE painting efforts "Naitiie" LOL or should that be p*ss off
Douggie
WOW LOL, Thats it...Id consider my Little Mono looks way better, more gloss and better cleared boat overall lol. My one picture sets my own example already man, All you did was take alittle masking and break it up..and let me tell you green white and yellow is a great looking combo for that Ul-1. " Douggie fresh" lol
LMT
ooohh.....and twit...lol wow good one man, how old are you again..like 80?? Your paint colors deff show your a$$ is from canada.. lmao!
LMT
No clearcoat on any surface as it is difficult to repair and just a note 61 years old and the UL-1 was done in Green Bay colours. How old are you???
Douggie
Wow no clear hmm. Dude now your asking me all these personal questions.....
61 year old weird guy.
Just forget the whole thing lol...
LMT
Lacquers and enamels don't need to be cleared (but can be) as they will give you a gloss finish. The uros do need to be cleared as they are part of a BC/CC system. The base coats will not give you a gloss finish and are not meant to that is what the catalyzed clears are for. Alsa, House of kolors, and others have come out with spray can versions of their paint but it is not the same as the tins you get from a jobber.
IMPBA 20481S D-12
Ok coming from a guy that 61 and still playing with RC boats...Wake up man!!! lol
LMT
As I have used Also on the Green Mono and it was dull after it was painted, It needed clear...
After 2 coats of clear it was waxed and looked great..
LMT
I trust that you will be playing with something when you are 61.
Douggie
Nice looking boats, Douggie.
As we used to say way back when we first started seeing clear coating...clear is for queers. That was only because our spray guys felt they could do a better job without covering up the scars from sanding with clear. Emron, etc never used clear. Paint it and buff it out and it looked a mile deep.
I use clear but an't no queer...but I am willing to learn :)
Clear can strengthen and protect as well as fill in minnor marks in hull as it is sanded and painted...
LMT
I can't believe some people are so dumb lol...
LMT
Paint two boats the same and the boat cleared will wax out and look much better promise...
LMT
Also Ill hope to have somthing better in life when Im 60 except blow all my money on boats...
LMT
