Results 1 to 21 of 21
Thread: new Turnigy 120amp 180 amp esc
    Aug 2008
    3,071
    Default new Turnigy 120amp 180 amp esc
    Anyone seen this or is it just new to me?
    https://unitedhobbies.com/UNITEDHOBB...idProduct=8921
    Jun 2007
    BC
    5,190
    The Turnigy ESCS are very good value but they are large. I do not water cool the ones I have as their size does not warrant it. I am talking about the HV and high amperage units. They may not fit in small boats and get enough air cooling. Also all of mine needed (3) required a Pistix to function, that may have changed today
    Douggie
    Aug 2008
    3,071
    Quote Originally Posted by Flying Scotsman View Post
    Douggie
    What I meant was this looks like a new upgrade of the popular Turnigy 100amp hv
    that is so used in FE and it will run on 12s
    do you a run fan on yours Douggie?...how big a boat do you run them in
    Jun 2007
    BC
    5,190
    No to the fan. a 32" mono, a 34" cat and a 29" mono and all are HV ESCS
    Douggie
    Jul 2008
    NC
    838
    Mar 2009
    AZ
    1,320
    So douggie, your not cooling them at all. They dont get hot?
    Jun 2007
    BC
    5,190
    Quote Originally Posted by 6S HYDRO View Post
    Nope, the heat sink is huge. This is for the 100amp HV esc. I can not speak for the new series.
    Douggie
    May 2008
    AB
    1,465
    I built a test stand to load test my motors and lipo's with a Seaking 180 , here is some video for what its worth
    http://www.youtube.com/watch?v=KmX2NABdHFM
    May 2008
    OH
    774
    Nice Job as usual!
    Camara need to be closer to screen, can't read data headers.
    May 2008
    AB
    1,465
    Sorry about that I will re-do this video but need to buy a smaller prop for load , a 10/6 is to much for this motor and I don't want to smoke another high power high end unit
    May 2008
    OH
    774
    I run an 8x4 on big motors and 7x3 on 4s motors.
    May 2009
    ON
    3,180
    This ESC looks good to me for the buck.... How would this compare to Castle ESC?
    Aug 2008
    3,071
    I cant get my turnigy 180amp to give me full voltage.....I hope its my fault..hate to think I got a bad one
    May 2008
    AB
    1,465
    Nick Can you post what your setup is and settings on the ESC , I find if I have the 3.4 volt cutoff even fully charged batteries hit the limiter very quickly and will not give full power on the test stand , maybe 30 seconds and thats it , 3.2v is what I set the cutoff at under load
    I am sure it can easily hold its own against one , at least you don't void your warranty if you run 6S
    Aug 2008
    3,071
    Peter
    Its my mean machine cat
    I used the optional programer set at
    Forward only
    Low start
    LVC at 3.2 per cell
    Low timing
    Flight power 2s 5000mah 25c x2 in series
    2200kv castle neu motor
    Boat would only go 23mph......soon as I switched out the esc she ran 43mph
    Using a m445 prop
  16. #16
    Aug 2008
    3,071
    Peter
    Forward only
    Low start
    LVC at 3.2 per cell
    Low timing
    Using a m445 prop
  17. #17
    May 2008
    AB
    1,465
    Jeez I don't know Nick I am at a loss . sorry my friend
  18. #18
    Aug 2008
    CO
    7,080
    So, any news Nick? I just got bullets soldered on and would like to test, any tips?
    "Look good doin' it"
    See the fleet
  19. #19
    Aug 2008
    3,071
    Jesse
    I havnt had it back out again yet but hope to tonight
    I also hope its a programing issue user error
    Getting it to recognize full throttle
    Hope yours works fine will give me hope
    GL bro
  20. #20
    Aug 2008
    CO
    7,080
    how many cells bec does this have? I didn't get a manual with it...
    See the fleet
  21. #21
    Aug 2008
    3,071
    Quote Originally Posted by Jesse J View Post
    I would suggest not using it but thats just me
    Constant Current: 180A
    Burst Current: 360A
    Resistance: .0007ohm
    Battery: 2-6S Lipoly
    BEC: 5.8v/ 3A
    Motor Type: Sensorless Brushless
    Size: 72 x 68 x 34mm
    Weight: 165g
