Results 1 to 5 of 5
Thread: ETTI verse CASTLE 240
    Jan 2009
    ct
    1,087
    Default ETTI verse CASTLE 240
    Are the Etti 150 30 volt comparible to Castle 240 esc's. I run a 1521 1.5 d motor on two 11.1 volt batts.The Etti's are much cheaper but dont know if it will hold up. Any input? Thanks
    Aug 2008
    Tx
    586
    Gary,
    Etti is reliable esc, but its still 150A, CC240 is 240A and look like people rolling dice when buying Castle, but to me, Castle been very reliable to me so far, with your setup you should go for CC 240 for peace of mind, dont worry about Castle quality that much because they are reliable and they also have outstanding waranty backing it up.
    Mar 2009
    AK
    391
    I guess the warranty depends on the application I know in some instances there is no warranty
    http://www.castlecreations.com/suppo..._boat_apps.pdf
    Cheers Adrian
    Aug 2008
    Tx
    586
    Quote Originally Posted by EPower View Post
    Cheers Adrian
    That is their protection, unless you dont do dumb thing like, soak them in water for hours, running more than cell limit..., then they alway cover it for you, they never rejected me even with flashing water damage, if its still under 1 year then you will be ok.
    Mar 2009
    AK
    391
    that's a fair comment i did look at the castle 240HV for my big V hull but decided to buy the Schulze fut-40.160 WK
    Cheers Adrian
