[QUOTE=no stick;74056] You need two, one for each battery for the UL-1 unless you can figure a way around it.
You only need to interrupt the jumper wire of the stock harness between the two batteries. Use ONE of those gizmos; cut off the deans, cut the jumper & splice the red wire(s) to each end.
