In between the using of this lower unit with a brushless motor, if I don?t use it too frequently, what maintenance do I need to be doing ?
Really appreciate it
You should pull the stub shaft assembly out along with the cable at the end of the day and soak the cable in ATF or your preferred lube. I would do the same for the stub shaft assembly.
Tyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
Keep in mind. The the stub on an OS is a left hand thread.
