Hi all,
First post here.
Me and a team (we're in the UK) are building a single seat electric endurance car. Not RC I know, but it will share a lot of the technology. We started looking at motors several weeks ago, with efficiency being the primary goal. We started with Astro, then Neu, and finally landed on Lehner. After comparing the datasheets (of which Lehner's is by far the most useful) we're pretty set on the Lehner TorqStar 1 7025 in the 40 wind configuration.
I asked Andreas Lehner which ESC would go well with this motor and he has pointed me to a German consultant that deals with the VESC controllers. He charges for his time (no issue with that) but before we stump up the cash I wanted to ask around on a few forums and see what other people think.
Our battery pack uses LiFePO4 cells. It'll be 93.6v right off the charger, and will fall quickly to 86v under load. The cells will be ready for recharge when they get to around 80v approx. We'll be averaging around 630w, with peaks of maybe 1000w (I know this is child's play wattage for you guys).
However, looking at what's available, it's our voltage that narrows things down a bit - most ESC's not going high enough.
There are a couple of models that are rated to 100v, but that includes peaks. I don't know how or when our pack may introduce peaks into the power line, so I don't know if 100v models will be right for us. Anyway, assuming they are (and we can fix any voltage spike issues), here's what I've got shortlisted:
APD UHV 120v/300a - $2500
https://neumotors.com/apd-electronic...ushless-esc-2/
APD HVPRO 100v/200a - $1900
https://neumotors.com/apd-electronic...brushless-esc/
MGM HBCI 110120-3 120v/110a - $1250
https://www.mgm-compro.com/brushless...r-controllers/
VESC STR-500 100v/500a - ?895/$1120
https://trampaboards.com/vesc-str500...--p-35876.html
VESC 100/250 100v/250a - ?375/$470
https://trampaboards.com/1x-vesc-100...h-p-28115.html
Our main goals here are:
- Works well with the Lehner motor
- Efficient
- Reliable
- Forward and reverse
- CANbus data transmission
What are your opinions on these speed controllers in conjunction with the lehner? are there other ESC's out there that are better for the job?
I welcome any questions, and thankyou for your time in advance!
Jim
