Results 1 to 12 of 12
Thread: Anyone making 8mm parallel adapters?
    May 2014
    636
    Default Anyone making 8mm parallel adapters?
    In the past, I've made a "Y" with several inches of 8ga wire. But I'd like to make a block, for neatness and shorter length. Would appreciate seeing some examples.
    Ron - The Villages, FL
    May 2009
    AB
    483
    I?ve made a few by pinning together the three bullets with copper rod and soldering it all together. I insulated it with a moldable silicone putty that hardens but I forget the name. It came in different colors in small packs like ketchup.
    Namba District 16
    9,402
    I cut copper bar on the lathe. holes are for wire leads and cap pack.
    Jan 2019
    mi
    45
    2,731
    Is the silicone putty Sugru?
    ca
    6,963
    Food for thought
    May 2014
    636
    Thanks, guys. Now I am leaning toward a "T" configuration. Wonder if "liquid electrical tape" would hold up to the heat.
    May 2014
    636
    Food for thought
    Thanks. Would have liked to see what's under the heatshrink.
    BTW, Tony, I still run the Hot Stuff crackerbox occasionally. Real crowd pleaser.
    ca
    6,963
    Ron, the harness was basically made with 12 guage wire and lots of soldering. Drop in the batteries for 4S 2P and go. Simple clean plug n' play -El Neato.
    Glad you're still digging the cracker; my Jersey Skiff sits lonely and dusty.
    May 2009
    AB
    483
    Yes that was it
    Namba District 16
    Jan 2019
    mi
    45
    May 2014
    636
    Quote Originally Posted by Rlimits View Post
